View Full Version : Heating & Air Conditioning
Pages : [1] 2 3
  1. Thoughts on Vintage air systems
  2. Billet Specialties Tru Trac Serpentine Belt Accessory Systems
  3. LT1 & Vintage Air. Compressor?
  4. Should I install Vintage Air before paint?
  5. Anyone planning on buying a Vintage Air Frontrunner?
  6. Vintage Air on a 2nd Gen Camaro?
  7. 68 Camaro AC removal
  8. Vintage Air Install Pics WANTED
  9. 1st gen. Vintage Air install...
  10. pictures of where to mount the bulk head?
  11. heater box instal
  12. Where the heck is the plug for the heater fan?
  13. Factory A/C to Vintage system?
  14. Frontrunner
  15. Dumb Vintage Air Sure Fit questions.
  16. A?C problems after rebuild
  17. Vintage Air Alternatives
  18. Vintage air install - crimping lines
  19. A/C charge ports
  20. need heater help
  21. pic of factory ac car with vintage air ?
  22. Vintage Air Group Deal!
  23. Vintage Air, Hot Rod Air vs. Factory Air
  24. Vintage Air - Drain?
  25. what is the new origional a/c stuff worth
  26. Need contact info For American Graffiti
  27. A/C compressor
  28. R4 Compressor brackets for Gen1 sb?
  29. Best choice?
  30. Vintage Air Frontrunner installed.
  31. VA Hose Length
  32. 1st Gen AC with LS1
  33. A/C compressor noise?
  34. Classic
  35. Vintage Air Question
  36. Vintage Air A/C - defrost vents
  37. GM Factory AC
  38. Frontrunner questions.
  39. Front runner/March Perf/Billet Spec
  40. How well does the sure fit system cool?
  41. Anyone convert their factory controls...
  42. Digital Air Condition Guage
  43. Anybody got wiring diagrams for 98-02 Camaro AC?
  44. Vintage Air problems
  45. Removing 73 Camaro heater/evaporator box
  46. How do I, AC to non AC in a 73 Camaro
  47. will a '68 Camaro heater box fit a '71 Malibu
  48. Sure Fit to Gen II and bulkhead/lines questions.
  49. A/C lines
  50. Just wondering?
  51. Vintage Air Evaporator Case Mounting
  52. 55-57 Chevy AC KIT
  53. Hidden AC Hoses
  54. Vintage air condenser!
  55. AC Delete Box Resistor placement, 69 Camaro
  56. How to connect AN lines to heatercore?
  57. When to run the ducts?
  58. Vintage Air
  59. stock 69 camaro a/c to lt1 compressor
  60. Drier Location
  61. 4th Gen Dash & AC
  62. Installing Vintage Air Gen 2 in 67 Camaro
  63. Heater & A/C Controls
  64. an 10 adapter in water pump for heating?
  65. Ditch the a/c?
  66. 69 camaro compressor location
  67. ac delete walkthrough?
  68. Gen 2 Vintage Air in 1st gen
  69. Vintage Air users with automatic trans coolers installed
  70. Big block blower housing on small block car
  71. Anyone get hold of CAA
  72. Doc's Blocks
  73. Anyone Need an AC System? Vintage Air
  74. Ac
  75. R12 private purchase.
  76. What compressor with LS1 and Vintage Air
  77. Anyone Fabbed up a Block Off set for the Heater Box assembly?
  78. Need a vintage air kit -compressor for 68 Camaro
  79. 69 Camaro with AC (need a source for cables)
  80. AC compressor mounting position
  81. How much should I remove?
  82. LS1/LS2 heater connections
  83. 68 Camaro heater box
  84. Does your a/c really work?
  85. ac fitting availability
  86. Vintage Air in a Non-Air Car - Value?
  87. Vintage Air install help!
  88. Center Dash Vent??
  89. Vintage Air question too
  90. AC for a '68 Camaro
  91. which refrigerant?
  92. Capillary tube?
  93. Want a smooth firewall but need heat and defrost, Options?
  94. ac brackets
  95. heating & airconditioning
  96. Clutch slipping problem
  97. My air does not work. Pretty broad statement, but I need help
  98. Does anyone make a??
  99. A/C compressor mount for BBC with electric water pump???
  100. Moving the Accumulator on a 79 Z28
  101. 68 Firebird with Factory AC to Vintage Air
  102. Heater core gasket placement
  103. Old A.C. restoration
  104. Heater Core Change out
  105. 68 Camaro Sure Fit A/C Kit
  106. Vintage Air Installation
  107. Crimping A/C hose ends?
  108. where to get 72 camaro AC vents?
  109. Second Gen Camaro AC System
  110. 71 Blazer heater core R&R
  111. AC bracket question...PLEASE!
  112. 76 Corvette - switch from A/C to heater only
  113. AC vents(really cheap material)!!
  114. Vintage Air
  115. Heater hose fitting question
  116. Gen3 compressor clutch options
  117. Nova headache
  118. Classic Auto Air / 2nd gen camaro
  119. where can I get compreesor clutch for this setup??
  120. Rear Defrost???
  121. AC in a Olds??
  122. 2nd gen with ls1 a/c questions
  123. classic auto air install question
  124. Vintage air in a Mopar
  125. Rebuild or replace?
  126. Now taking orders for Vintage Air Camaro Gen IV systems
  127. Heater core
  128. R4 compressor or Sanden?
  129. HVAC case underhood - WTH is this?
  130. a/c recommendation
  131. Lt1 and vintage air
  132. Heater House Options ?
  133. A few facts about AC
  134. VA heater control valve placement
  135. Going with A/C finally Need some help
  136. Want Ac In My 71 Ls1
  137. AC in a 68 Charger
  138. A/c And Heater Controls
  139. 1st gen Camaro AC
  140. Convert the head unit.
  141. RPM drops when turning A/C on
  142. A/C compressor on the passenger or driver side?
  143. Compressor/rad hose
  144. 71 camaro A/c controls
  145. 67 firebird A/c heating
  146. I want air on my 58 Nomad
  147. Do I or don't I?? HELP!!!!
  148. which A/C unit?
  149. 1967/8 Camaro Vintage Air Gen 4 install pictures
  150. Complete Factory A/C parts available?
  151. 70 chevelle A/C
  152. Fords w/A/C
  153. Vintage air gen IV and factory kick panel vents
  154. If A/C not cold enough.
  155. Slipping A/C clutch
  156. A/C theory question
  157. Looking for SBF serpentine pulley system
  158. what AC kit is this?
  159. German Fog Machine
  160. Using stock A/C system with 69 FB LS1 conversion
  161. vintage air w/ custom bulkhead
  162. heater options
  163. A-Body Radiator Support/Cover - any aftermaket Aluminum or SS?
  164. Adding a vent
  165. where can i have custom ac lines made?
  166. Need some ideas on hose routing and cleanup for A/C.
  167. Vintage Air LS1 bracket
  168. Where to start??
  169. 68 Camaro factory AC VA question
  170. 69 Camaro A/C Removal
  171. A/C Vents
  172. Classic Auto Air Mustang kit ?'s
  173. Aftermarket AC for 72 Nova that came withAC?
  174. Repairing stock AC boxes
  175. electric a/c compressor
  176. Heat/ AC Bulkhead Which One?
  177. Hardcoat (black) Vintage air pics needed
  178. Heater blower motor doesnt turn on, where to start?
  179. Anyone running a Gen-IV system in a '68 Camaro? Dimension needed
  180. Aeroquip EZ Clip Air Conditioning
  181. Sanden conevrsion
  182. LS1 Swap in 68 cam. Is 00' AC setup junk or useful
  183. 69 impala
  184. Fan run keeps running
  185. Vintage Air/Firewall Questions
  186. Is air conditioning a must?
  187. A/c orifice tube location
  188. Vintage Air interior clearance
  189. A/C heater core question
  190. VA Gen II install questions
  191. waterpump question
  192. Heater question of '68 Camaro
  193. 69 Camaro Heater Control
  194. A/C adapter fitting
  195. VA or Classic Custom Air
  196. Aftermarket A/C for 2nd Gen Firebird
  197. VA Gen IV install in a 71 Nova
  198. Need help on Vintage Air ordering
  199. OE replacement for 396 auto?
  200. Frank- VA Bulkhead Question
  201. CSR smallblock waterpump
  202. melting heater core fittings
  203. Are V/A Gen IV mock up blocks vehicle specific?
  204. Getting Rid of Rear Hood Vents?
  205. Compressor locks up
  206. Vintage Air experts -- question about the Gen IV
  207. Vintage Air shipping
  208. Aftermarket OR Factory Air
  209. EPA presses for fast switch to A/C refrigerant R-1234yf
  210. Staggered 9-inch fans
  211. Gen IV vinatge air/cooling fan question
  212. Will Vintage air gen IV work with MSD box?
  213. Vintage air Install
  214. Vintage Air Dealer
  215. Lots of A/C Components... What will work?
  216. Heater core install questions
  217. Vintage Air/Factory Questions
  218. where do i get these parts?
  219. Pics of subframe cut out for A/C comp.
  220. Vintage Air Compressor Will not come on
  221. Cheap Heater Choice? Vintage Air?
  222. Vintage Air gen 2 work with Ls1
  223. Need an Vintage Air vendor in LA area that's reputable and reasonably priced
  224. got my va kit today
  225. A/C lines
  226. VA install pics
  227. Vintage air frontrunner price and/or opinions
  228. runnnig a/c, heater lines
  229. overheating!!!! HELP!!!!
  230. looking for a compact AC compressor
  231. AC line crimping
  232. A/C delete, anyone ever use this product?
  233. HVAC Bulkhead Routing
  234. changing a/c pulleys
  235. ac drain line routing
  236. 69 Camaro BB heater core......................
  237. BulkHead to Evaporator HELP
  238. Vintage Air Gen IV for Nova 66-67 and 63-65 are here!
  239. Whats the best after market company for AC
  240. Later Model Factory AC in 72 Cutlass
  241. Vintage air Gen4 related questions
  242. a/c condenser location
  243. Besides ugly hose routing, any cons to driver side A/C?
  244. vintage air with stock pump
  245. Anyone deal with Hot Rod Air Inc?
  246. Heater hoses
  247. Vintage Air on an LS2
  248. Braided A/C line type fro Vintage Air
  249. Vintage Air hoses inside the car
  250. Vintage Air Question
