View Full Version : Safety Equipment
- Saftey loop with 3" exhaust & X 1st gen
- Innovator Camaro rollbar
- Is this too much torque ?
- Gen. I Mini Tub fit questions
- why did you have a rollbar/rollcage put in?
- What should I use for undercoating my car?
- HELP, please strange noise @ 40 mph.....
- Anyone know how to build an adjustable frame table?
- G body cars with remote power steering reserviors?
- Safety air bag transplant
- LT1 power steering pump with AN fittings
- another cage by G-Machine
- Quick-release steering wheel
- Rag joint swap .
- tech/safety questions
- helmet
- I need Earl's Ano Tuff line alternatives
- Removable bars - z-joint?
- What harness would you use with these seats?
- Question about gas caps...
- Urgent!! Harness ?
- CAD model for a Cougar or Mustang??
- Steering Column Splines Flattened
- unisteer big block chev steering shaft kit HELP
- Factory Style Seat Belts and Racing Seats
- HUD in a classic?
- Need Rollbar for 68 Camaro
- 4130 TIG welded Custom Roll-bar
- Another 'cage/'bar question
- custom sub-frame connectors, 4130
- DSE wiper motor and clearance for brake booster
- 65' Chop top roll-bar
- Need help
- Cage question?
- How do tall people fit in 1st gens?
- black hose clamps
- tubular trans crossmember question
- '96 LT1 Corvette Vacuum lines help needed.
- those fancy plastic hose clamp thingies
- Seats, belts and bars?
- A Horny Question
- Steering Column Removal/Installation
- Really just venting, but...
- Insurance in Sept. PHR
- Kirkey Road Race Seats
- square tubing cage
- Upgrade 65' Impala belts, headrest?
- 69 Gastank on a 68 Camaro
- Engine / pinion angle. (Pic.)
- Roll Bar/Cage finishing
- Harness bar with no cage??
- 5th Generation El-Camino Roll-bar pics ?
- Need 67 A-BODY Frame dimensions ASAP!
- Autocross Helmet
- JEGSTER Chassis/Roll Bar Kits......
- 69 Camaro Project
- Recomendations for seats, belts and minimum rollbar?
- Battery disconnect with rear mount battery?
- 68 Camaro rollcage the same as a 68 Firebird convertible cage?
- Measuring chassis deflection
- recent chromoly cage install
- strengthening my frame????
- Roll Cage Weight???
- Making gas tank straps
- Roll Cage
- jegs 8 point camaro cage anyone use it
- roll bar in a full frame car
- Rear Bulkhead
- Roll cage problem
- Rear 3 pt. in a Chevelle Vert?
- time for roll bar?
- safety loop location
- Not Pro-Touring, but Tahoe safety question
- Roll Cage Main Hoop
- how do i do a seat harness w/out a roll cage
- Roll Cage Question
- G Body Racing Harness Mounting
- best 3 point seat belts for 1gen camaro??
- Guess what? Fire melts aluminum!!!
- Sealing the gas tank sending unit?
- Least Obstrusive Roll Cage
- Oval plastic tubing
- Why doesn't Aeroquip make a 120* Socketless -10 fitting in Nickle?
- 6pt rollbar w/removable bars in convertible
- Show off your 1st gen camaro Roll bars!
- Aeroquip High Pressure Hose & Fitting HELP
- Good Gas Cap for 67-68 Camaro?
- 1st Gen Camaro Aero woes..
- Power Steering Cooler Installed
- Rick's Stainless tank owners - Clear coat?
- Does a linkage type pedal mount in stock location?
- F Body Bolt in "Firewall to frame" bars
- Frame question about Gen1 Fbodies...
- Stainless steel fittings
- Need a quick answer before I go look at this car
- Opinions on streetable ground clearance...
- Saftey Check: Everyone Should Read this!
- Custom Side Glass
- I need help figuring out this gas leak.
- Making my 68f-bird safer
- starter tech
- Seat braces with roll cage.
- 1965 Chevelle 4 season car cover
- quick question on rollbar install
- How NOT to install seat belts...
- No KEY need help to get cylinder out
- 1st gen 3-point seatbelts, convertable, maybe
- Fuel Tank options for mini-tubbed 68 Camaro
- Stinkin' hard fuel line.....
- 73 nova hatch, gas tank idea.
- Are slosh baffles in a gas tank worth it?
- Fuel Tank strap mounting tabs
- convertible pro-touring car & safety ???
- braided or hard line?
- ATS Lee 670 Steering Box vs. Header
- Stainless windshield trim flew off
- Power steering help!!
- sea foaming
- donor car options
- MotiV8r needs a 5 point harness. Help me pick one.
- The 14 Car safety thread, Roll Cage, Kirkey seats,Fire systems
- A-body Parking Brake Modification
- Pull up or pull down harness
- What the heck do these hood hinges go to?
- shaved door handles
- Does This Sound Right???
- 5 Point harness recomendations.
- Rear firewall 1st gen Camaro
- Where to mount Washer pump??
- power steering fitting question.
- V - belt P/S pulley
- Fuel Line routing
- poor man's gear box help!
- NPT to AN Conversion Chart
- modified fuel tank 69 camaro
- Does anyone work for Cadillac/GM need some tech info?
- What are some High temp ignition wires?
- 68 Camaro Subframe Alignment help
- Need pic of windshield washer nozzle installed
- Camaro vs Nova Floor Pan?
- Pedal set up.
- gas tank strap "pads" or "dampeners"
- weight loss sugestions
- Where to run fuel line?
- roll cage question
- Early Mustangs...
- Convertible pro touring camaro considerations
- Fuel Pick up questions
- Fuel Sump position on stock tank
- Anti Seize
- Need help with interchange hood cable
- Anyone use Koul Tools for putting on braided hose ends?
- Roll Cage Question - 10 point Sufficient for Autocross, Top Speed, Etc?
- Need Flexible Fuel Hose - filler neck to tank
- Remote Fuel Filter locations?
- New Gas Tank
- starter question
- roll cage material
- Early Mustang rollcage/bar pictures
- 3 Point Seat Belts -vs- 4 Point Harness
- Safety checklist for a mainly-strip car!
- Billet Washer Reservoir
- Fuel Cell Questions, Which One?
- power steering cooler
- What is considered a firewall? Fuel Cell mount question.
- A-Body Manual Steering to Power Steering question.
- aloha camaro roll cage
- Is this the correct master disconnect?
- Non OEM 70 Chevelle chassis question
- speedometer cable
- Racing seat shoulder strap slots lower than shoulder. BAD?
- Roll bar or No Roll bar
- any good pics of a road race type cage in a Monte SS?
- 69 camaro power top issue
- rear fuel vent question
- rollbar seals/grommets
- Camaro intank fuel pick up
- Crossmember material
- Remote power steering resevior height ?
- Gas Tank Vent
- Power Steering Control Valve
- H.D throttle setup
- new vs old safety technology
- welding other 'stuff' to roll cage
- Driveshaft loop thickness???
- Cadillac 472
- Race Day seat belts ?
- Fuel line questions 69 Camaro
- 96 Grand Am no start
- 3 point seat belts for a 70 camaro
- Trans Cross Member
- roll cage quick release
- Motor mount issues!
- Vibration in Camaro
- Relocating battery to rear beneficial for pro touring cars
- Steering box adjusting
- short throw shifter
- Quick opinion needed - Power Steering Line routing (pics inside)
- Pedal Talk
- Help with fuel line!!!
- 2nd gen tail light question
- Baby seat
- AMSOIL Technical Question Thread
- quick speedometer question
- 2009 Chevy Malibu vs 1959 Bel Air.....ouch
- Air filter recommendation
- Identify this mystery goo
- Spare parts prices overseas
- Making chrome look like brushed alluminum???
- 351w fidanza flywheel question
- 70RS Build... Hood Clearance w/ 502 Ramjet?
- Radiator cleanup
- Convert firewall ??
- Fuel return line
- Mustang roof flattened -- Roll hoop failure?
- Upping Safety in my 70 Chevelle
- Using a Fuel Cell with out Tubing the Car
- roll cage setup?
- Spool rear end, I don't like it.
- 1967 Taillights and no back up lights, is it legal?
- Improving Safety. Direction Please.
- Air Rides, Tiger cage
- g-body o-ring questions
- Converting from auto to manual pedals...same mounting bracket?
- Roll cage, SCCA vs others
- four point seatbelt without a roll bar???
- 2001 expedition wont start
- Camaro vs. Camaro - Which Generation Would You Build?
- looking for a good helmet for the $$$$
- 2010 Dodge Journey dead any Chrysler Techs?
- Rollbar nightmare, cut it out of the car today
- polyethylene Gas Tanks
- Morris Seat Belts: Invest in your Safety
- Spoiler options
- Whats the best way to get an Edelbrock aluminum intake smooth to polish it?
- How good is the polish job on Factory Polished Edelbrock Intakes?
- Fastener question(s)
- Roll cage
- Safety discussion split from Optima thread
- Ordered Schroth Rallye 4 harnesses for the GTO yesterday
- Need a Helmet
- Seat belts in a convertible, mounting??
- SHOCK DOCTOR Eject Helmet Removal system
- building a chassis
- 70-72 GM A Body Quarter Window Weatherstrip Question
- Need a harness bar
- Fiberglass Bumpers on Street Car
- wish I knew someone to fix a steering column
- Power steering clearance issues
- harness opinion
