    Results 1 to 16 of 16
      Oct 2015
      ankeny,iowa
      I need help doing ls1 swap into 69 camaro.
      I just got off the phone with dirty dingo about ordering motor mounts and oil pan. I was told by their Tech guy that I didn't need an oil pan other than the stock F body oil pan on the LS1 is this correct I need to know and also if anybody can help if I ran the dirty dingo adjustable motor mounts would it slide the motor enough to use LS1 Kooks inch and 7/8 to 3 inch collector headers
      Mountain Springs, Texas
      The F body pan will barely fit if you slide the engine all the way back to the firewall. Less than ideal and you don’t see many folks doing that anymore.
      Check out the Holley mounts, acccessories, and headers. They work together for a clean install...
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Oct 2015
      ankeny,iowa
      So i should order the holley pan ? Doea anyone have a part number. Please. I will dig through threads. To see if i can find. It. But 2 kids and long work hours. Ughhh
      I was suggesting you buy everything Holley and skip the Dirty Dingo sliders, Kooks headers etc. Go with a proven system so you don’t waste your time spinning your wheels...
      Don
      Oct 2015
      ankeny,iowa
      Thats the answer I was looking for just because I'm ordering all this stuff doesn't mean that I have all this money laying around to do it twice and three times it's taking a very very long time for me to Mass to be able to even begin this and the help is greatly appreciated
      Apr 2010
      I have a 69 camaro with stock ls1 oil pan. Used adjustable motor mounts to slide back. Your cylinder heads will be approx. 1/2" - 1" inch away from the firewall to have enough clearance between the suspension center-link and oil pan
      Quote Originally Posted by brycedrue View Post
      With a T56? What sort of tunnel mods and driveline angles?
      Jul 2016
      T56 ???? I didn't see a T56 mentioned Hmmmm.
      Jul 2016
      Purchase the Holley LS swap products, Motor mounts, oil pan, headers. What transmission are you going to use ??
      Apr 2010
      I'm using t56, drive line angle around 3.5 degrees. No tunnel mods. I might have messaged with a body hammer in one area. Did not cut anything...
      Apr 2010
      But if I was to do a swap all over again, I'd go with the holley kit. Saves a lot of time
      Oct 2009
      will the holley headers clear the steering rod for a rack?
      1969 frost green camaro
      LS3
      Speedtech pro touring front subframe
      ridetech rear 4-link
      moser 12 bolt eaton tru trac 3.73
      Quote Originally Posted by Sinnister69 View Post
      Using a rack and pinion on a factory subframe is a bad idea. Bump steer among other issues. Use a quality 600 steering box with rack valving.
      Don
      Nov 2014
      Holley headers will not clear a unisteer rack on a camaro (I tried). The rack made the swap a real pain, but found the following to work; GM BBC camaro frame stands (moves the engine 3/4" towards passenger side), DD sliders, moroso solid motor mounts, Stainless Works headers, Autokraft oil pan, and Speedtech transmission X member. This is for LS and T56 magnum in 1967 camaro. Also, I did not have to cut the tunnel.
      Last, we do not have bump steer trouble with ATS tall spindles and arms. Thanks
      Nov 2011
      Country Flag: Norway
      I used:
      https://www.mastmotorsports.com/prod...ion-oil-pan-pt
      Doug's Headers D3341 1 7/8" 4-Tube Full Length Header Chevrolet LS1 Engine Swap Camaro 67-69
      Doug's Headers SK100 Motor Mount Adaptor Plate Kit for LS1/LS6 GM engines into 67-81 Camaro
      Motor mounts https://www.summitracing.com/int/parts/sum-7731114
      have a unisteer rack and pinion with the big block kit had to add a 5mm spacer on the motor mounts (There may be som better motor mounts so you dont have to buy the spacers)
      PSI wiering harness https://www.psiconversion.com/
