      Tacoma, Wa
      Moser 12 bolt axle bearing
      Hello everybody,
      Thanks ahead of time for answering my question; It may be obvious for some!
      I ordered a moser 12 bolt with c clip eliminator, bolt-in axles. I tried installing the axles tonight only to notice the bearing pressed on to each axle sticks out nearly 1/8" past the bearing end welded on the axle tubes - (The bearing itself when installed is not flush with the brake mounting surface at end of cap). Does this have any significance at all? Am i over thinking this? Should I Just bold the retainer on an call it good? Thanks for your 2 cents on this matter.
      These two shots show the bearing end and bearing pressed on the axle just as they were shipped.
Size:  96.8 KBName:  photo(8).JPG
      Brian
      68lovebuzz
      68 Camaro, LS6, TKO 600, Moser 12 bolt 3.73 W/Eaton LSD, hotchkis/bilstein, KORE3 C5 brakes, RUSHFORTHs and a few other tweaks ; )
      Jul 2008
      Ft. Worth, TX
      Yep the bearing will stick out some and retainer goes on it. Just like a new style big ford end.
      Feb 2007
      I thought the same thing when I installed my axles. but they will stick out a little.
      Brandon Slater
      1979 Z28
      1972 Nova
      2015 2500 silverado crew cab duramax
      Tacoma, Wa
      Quote Originally Posted by brownz View Post
      Thank you for the information. The **** that keeps me up at night! hahahaa. you guys are awesome.
      Brian
      68lovebuzz
    Tags for this Thread
