Results 1 to 20 of 20
11-05-2005 #1
Another electric water pump question
I am thinking about running an electric water pump on my SBC. It is going to be used on a street car.
I am looking for peoples experiences with electric pumps, and the different brands and models.
I am not looking for "Don't use and electric pump!" unless you have actually had a bad experience with them.
Please explain your setup (how long you've been running it, how it's controlled, volume, etc.)
TIA! :drinkup:
11-08-2005 #2Registered User
- Oct 2003
- 277
Meziere Electric pumps
I have been running a Meziere remote mount 55 GPM electric pump on my daily driver since last April. ('73 Porsche 914 w/350 Chevy Conversion & A/C) I drove the car all summer long here in Phoenix and we had some 117 degree days. I know of at least 5 other local guys running the same exact pump with Zero problems.
11-08-2005 #3Registered User
- Nov 2004
- 261
porschev8
Sent you a message about your Meziere pump setup.
Thanks, Gerald
11-11-2005 #4Registered User- Join Date
- Oct 2003
- 277
Originally Posted by TUBED
11-11-2005 #5Registered User- Join Date
- Nov 2004
- 261
Tim,
I was wanting to see how your remote Meziere setup was plumbed on your ride, do you have any pictures? I have a 68 Chevelle that I'll be using a Meziere remote pump on and was curious after reading this thread. Just PM me if it's easier.
Thanks, Gerald
11-18-2005 #6Registered User- Join Date
- Oct 2003
- 277
Is there any specific reason why you want to use the remote mount pump? It would be much cheaper & easier to use their engine mounted 55 GPM pump. This is a picture that I found on the web. I don't have any photos of the pump installed on my car.
http://www.meziere.com/2005_catalog/29.pdf
11-18-2005 #7Registered User- Join Date
- Nov 2004
- 261
Tim,
Thanks for the reply and don't worry about the pictures if you don't have any. As for running the remote setup yes it's more expense but I like the different design plus it'll clean up the front of the engine and make the Jesel belt drive easier to adjust.
Gerald
11-19-2005 #8Tim, that's a pretty nice set-up I'd say. Do you have any idea how many hours the pump is rated at for reliability? I'm guessing this is a race only pump and not intended for the street but I'm curious anyway. -Jabin
Gmachinz Sales and Performance
"updating the level of performance..."
[email protected]
*never argue with an idiot-they'll drag you down to their level and beat you with experience!*
11-19-2005 #9Registered User- Join Date
- Nov 2004
- 261
Jabin, the remote Meziere 55 gallon pump can be used in either application (street or drag racing). I'm not sure how many hours of life they have in them (I know you asked Tim not me) , but they are equal to the block mounted design just have different housings. I hope this helps.
Gerald
11-29-2005 #10Registered User- Join Date
- Oct 2003
- 277
10,000 hour life expectancy
Originally Posted by gmachinz
12-04-2005 #11Registered User- Join Date
- Oct 2003
- 277
followup
The pumps have a average life expectancy of about 40,000 miles according to Mike @ Meziere Enterprises.
12-05-2005 #12Hmmm...an electric water pump with a pretty good service life behind it freeing up HP and it can also be controlled with a progressive controller too...got me thinking here. I may have to experiment with this one. -Jabin
[email protected]
02-15-2007 #13New to Pro-Touring- Join Date
- Feb 2007
- 58
Still curious if the remote pump adds to the life of the pump? Trying to figure out if the engine mounted pump is affected by engine heat. Obviously, both will work, but is durability considered about equal?
02-15-2007 #14Believe it or not, i run the "Proform" electric waterpump on my twin turbo 400" motor.....this thing cruises at around 165-170* in the city....i've put over 1500KM on her last season without a hickup of the cooling system. Im using an aluminum rad 31x16 (s10 style) and a Taurus fan wired on the 1st speed, slowerer setting.
No problems here & its going on season 2 this year in the new car.
-Carm
'69 Firebird Twin Turbo SBC 400" Blow-through
9.80 @ 141 w/ 1.88 60-ft..... on 17's
9.21 @ 153 w/ 1.45 60-ft..... on PUMP GAS
8.60 @ 164 w/ 1.46 60-ft..... on RACE GAS
02-16-2007 #15Registered User- Join Date
- Nov 2005
- 38
If you need cabin heat, make sure you plan for it. Most electric pumps dont have provisions for it.
02-16-2007 #16New to Pro-Touring- Join Date
- Feb 2007
- 58
I didn't know that. Thanks for the tip.
02-26-2007 #17New to Pro-Touring- Join Date
- Sep 2006
- Zelienople PA
- 59
I ran a Meziere on my last car....a 1994 Formula LT1 w/ Procharger. Was running around 525 RWHP and the pump would keep the car running well under 200 degrees. Only problem I ever had with the pump was when I somehow blew the fuse in the main power line going to the solenoid. Did not know it happended and seriously overheated the engine. Did not cause any damage at the time as far as I know....sold the car a couple years later and it was still running strong. But the lack of power to the pump was a real problem!
02-27-2007 #18Registered User- Join Date
- Jul 2005
- 20
Stewart makes an in-line "booster" electric water pump, rated at 300 gph.
02-27-2007 #19Registered User- Join Date
- Aug 2004
- 149
