Results 1 to 18 of 18
Thread: Need Advice...
07-10-2009 #1Registered User
- Aug 2004
- Pittsboro, NC
- 194
Need Advice...
Hey guys,
I am contemplating whether to sell my 69 camaro to buy a Corvette Z06. If Im having major brain issues here, let me know. I am not sure what the price I should ask for, especially in this economy.
The paint is about 15 years old as I have had the car almost 10 and the previous owner had it painted 5 years before. There is only 1 bit of rust that I have seen and I have had the floorboard and trunk stripped down to bare metal. The small rust is on driver door down on lower side near front fender and I am fixing it whether I sell it or not.
The car is an original matching numbers SS. I have the original engine that will go of course with the car. The T350 goes as well, but have not checked those numbers. The car was an originial auto with T350.
Here are the mods etc I have done to the car. ~2500 miles on motor and trans. I have to look at odometer to get exact number.
Paint: Hugger Orange (originally Olympic Gold)
Wheels: Vintage Wheel Works 17x8x4.75 front 17x9.5x5.5 rear
Tires: 245/40/17 front 275/45/17 rear
Engine: Professionally built 355 cubic inch small block 475 HP @6400
Will provide all engine component details to potential buyer
Transmission: Tremec TKO-600 5-speed
Rear Differential: GM 12 bolt positive traction w/ 3.73 gear ratio
Brakes: Baer track system in front (13 cross-drilled/Zinc washed rotors), touring system in rear (12 cross-drilled/Zinc washed rotors) with Hydratechs hydraulic brake booster
Shocks:
Front: Koni adjustable coil-over designed by DSE
Rear: Adjustable conventional style
Suspension Modifications
Subframe converted to coil-over front suspension using the (DSE) Detroit Speed & Engineering coil-over conversion kit
DSE tubular upper control arms
DSE subframe connectors
AGR custom valved 12:1 power steering box
DSE tubular tie-rod sleeves
1 1/8 sway bar
DSE steel sleeves with Delrin bushings in lower control arms
DSE aluminum solid body mounts w/ stainless bolts
Hotchkis 2 drop multi-leaf springs in rear with additional Ύ aluminum lowering blocks
Ididit tilt steering column w/Borgeson joint
Toms Differential Axles
Interior Modifications
DSE steel custom dash - Autometer gauges with LED bulbs and ignition moved to dash
DSE hoop bar with removable cross bar
Custom made aluminum pedal covers
Corbeau TRS seats w/ 3 racing harnesses
Stock backseat re-covered to match front Corbeau seats with Corbeau 2 factory latch style seatbelts in rear
Dynamat Xtreme insulation installed throughout car to reduce road noise
& vibrations
Sparco removable steering wheel (horn still works)
CV Products aluminum shifter stick and ball
Anvil Arms Carbon Fiber Satin A-Pillar moldings
New carpet, doorpanels, window cranks, dashpad, rearview mirror, dome light
Other Modifications
DSE Firewall Fill Platel installed.
Car rewired with Painless Wiring 18 circuit harness and GM weatherpack connectors used for easy disconnects
Vintage Air Front-Runner serpentine pulley system
DSE aluminum hood hinges
DSE Billet Hood Latch Pin and Spring Collar
DSE aluminum close-out panel
DSE power steering pump & reservoir
Be Cool 4-core aluminum radiator w/ Spal electric fan
DSE selecta-speed wiper
DSE modern headlight kit
DSE aluminum trunk battery mount w/ optima battery
Flowmaster 2 ½ H-pipe exhaust system connected to 1 5/8 Hooker Super Comps w/ceramic coating
Marquez Design components
o aluminum marker plates, tail light markers, cubic inch numbers, aluminum door jamb vents, stainless hood adjusters, and stainless door strikers
Included with Car
Wilwood 1 1/8 Black Powder Coated Aluminum MC (new in box)
Prodigy Customs compete stainless bolt kit (new in box)
Original SS Hood
Original 69 seats
1970-81 2nd Gen Camaro bullet mirrors
DSE powder coated Compac bracket for Vintage Air Gen II system (new in box)
Turbo 350 transmission
Thanks guys....I willl post pics asap.
__________________
Jay
07-10-2009 #2
07-10-2009 #3
personally I wouldn't do it but you have to do what makes you happiest...
www.buickfunnycar.com
07-10-2009 #4
