    Results 1 to 3 of 3
      Sep 2007
      N. Florida
      Another new guy from FL
      ... and just like the guy I'm posting after, I have a Corvair, although it is not my pro-touring car.
      I have enjoyed (well maybe not always at the time enjoyed) putting Chevy V8 motors into other cars. I still have all of the below, plus a 2006 car hauler and a 1998 Durango to move them as needed.
      Past/ongoing projects:
      1975 Datsun 280Z with 1995 LT1/T56 from my Trans Am
      (Lost most pics of this car when my computer crashed last year)
      Summary:
      $900 car, I got it with two rear wheels on it, a basket case. I recycled the drivetrain from my 1995 TA into it and bought a bunch of used parts to get it to where I could move it. Still needs interior, body, & paint work and some finishing touches on the swap. Car has an electronic Cobra reverse-wind speedometer since I did not want to fool with a cable adapter box.
      1988 Toyota Supra with 2003 Chevy 5.3L LM7 truck motor/2006 TKO 600 trans
      Summary:
      I had a beater Supra as a commuter car several years ago, and thought it would be neat to put a V8 into one. I found this one for around $800 and picked up another wrecked one for less than that. I had to cut & weld a new spare tire area into it due to a large rust hole. I made all the mounts & brackets myself. I did not use a T56 here since it didn't look like it would fit in the trans tunnel. I initially planned to add a single turbo to this car, but could not find the room to mount it. This car also needs paint. It has a phantom glitch in that the tachometer only works while the car is in reverse- still working this bug and a few others out.
      1988 Mazda RX7 convertible w/ 2005 Chevy 5.3L L33 truck motor/1998 T56
      Summary:
      $900 car I got in Orlando. It had sat outside for a long time, but was complete and had a pretty good body (very few rust repairs). I found a junkyard 30K mile L33 5.3L motor from a 2005 Silverado SS for $800 (this is the 310 HP high output version of the 5.3L truck motor) and a T56 in good shape for $500. I used a Hinson conversion kit along with my own fabrication as needed. I added a Racepak electronic dash to avoid the speedometer cable issue. Car is completely operational, but needs a new top and an AC control panel.
      1995 Pontiac Trans Am 383 LT4 with homemade rear turbo/T56
      Summary:
      Mid-life crisis #2... or was it #3? I got this car from a dealer in Orlando in 2000. I drove it as-was for a while, and then picked up a 1995 motor & tranny from a wrecked Z28. I had a buddy rebuild the motor with LT4 heads and splayed 4 bolt mains and low CR forged pistons. Did the bore & stroke to a 383 as well. I later added a home made rear turbo setup (couldn't fit it up front and wanted to keep the AC). With the first dyno tuning, car made 498 RWHP & 579 TQ. Added C5 brakes up front & larger 98+ disks in rear, along with larger swaybars. Initially had lowering springs, but too many rubs/scrapes, so OEM WS6 springs were used. Car has a HD 12 bolt rear with 3.73 gears and ZR-1 wheels, 17x9 and 17x11.
      New arrival:
      1994 BMW 525iT w/ LM7 turbo (if it will fit) and T56.
      Plan:
      I picked this car up along with a wrecked '95 525 sedan w/ manual tranny. The plan is to swap the manual setup into the wagon (all imported wagons were automatic), and then add another LM7 truck motor and the turbo I had for the Supra. This car has the wide 18" M-Parallel wheels, which was one of the reasons I bought it.
      Oh yeah, the Corvairs are a 1965 Corsa Coupe & 1966 Corsa Convertible.
      I've had the coupe for 30 years and got the convertible a few years back. The coupe is a project in perpetuity, I added 4 wheel disks from an E-body Toronado and have made some suspension upgrades. The convertible is a really nice car. It had a motor issue and the one I got for it was not much better, it has a major oil leak I need to fix.
      All of these toys fit in a 60x40 toybox.
      I moved in 2007 and this disrupted the projects, I hope to get back on track this fall.
      Jul 2002
      Mesquite, TX
      That's quite the collection. Welcome to the site. What do we call you?
      Jun 2002
      Long Island, NY
      Wow, you've got some awesome projects/cars. Welcome to the site.
