    Results 1 to 20 of 25
      Jun 2009
      Central FL
      C5 brake people, what studs did you use?
      Anyone who installed C5/LS1 brakes, what size studs did you use? The stock ones are too short for my rotors and spacers, so I need to upgrade. No auto place near me has studs with the same knurl and shoulder as the stock studs. Any ideas?
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
      Jun 2009
      Central FL
      Whoops, clicked the wrong subforum, can any Mods move this to brakes, please?
      Dan
      1968 Camaro v2
      Pensacola, FL
      Try a napa hub store- the one with the parts wharehousein back. Not sure if you have one there, but they had a ton of studs. My front C4 spindles had long studs in them for wheel spacers & i had to find shorter ones- go figure. I may still have the long studs- what length do you need?
      Scott
      Jun 2009
      Central FL
      I need about 2.25 to 2.5 inch. I've found a set from Moser that's 2.85, but I think that's too long, it might stick out past the spacer. I think the Napa I went to has a warehouse, me and the guy there spent over an hour looking through books for a stud that would fit, we had no luck.
      Dan
      1968 Camaro v2
      Dripping Springs, TEXAS
      I bought mine from Summit..
      Moser 12mm x 1.50RH
      2.50 Underhead length
      http://www.summitracing.com/parts/MSR-8255/
      Jun 2009
      Central FL
      Quote Originally Posted by Throttle View Post
      Moser 12mm x 1.50RH
      Holy crap, .505" knurl, will that fit a first gen?
      Dan
      1968 Camaro v2
      I have a kit that has 3rd Gen Camaro Hubs.. You can always drill them out.. Factory a 1st Gen is .472 knurl, So I would see if you could drill them out to fit bigger.. I did it on my Brother Mustang..
      Here are some pics of the brakes for the 72 Camaro..
      Camaro Big Brake Kit by throttle_junkie1972, on Flickr
      September 12 2008 004 by throttle_junkie1972, on Flickr
      March 31 2009 012 by throttle_junkie1972, on Flickr
      Jun 2009
      Central FL
      3rd gen hub? It fits fine? Would a 4th gen hub fit, too?
      Dan
      1968 Camaro v2
      Dallas TX
      I used ARP but I don't remember the part#. They were 3" and I cut them down to the length I needed.
      Jun 2009
      Central FL
      Quote Originally Posted by gearheads78 View Post
      I thought cutting the stud would cause some loss in strength...?
      Dan
      1968 Camaro v2
      Dallas TX
      Quote Originally Posted by Vicinity View Post
      Other than maybe at the 1st thread or 2 how would it loose strength. I cut them so they would be engaged in all the threads in my lugs. My 1st cut was about 1/8" long and I ground them down to final size on a belt sander and tapered the edges a little to ease starting.
      Jun 2009
      Central FL
      I read it on the internet.
      Dan
      1968 Camaro v2
      Birmingham, AL
      Do you remember the specs that you turned down the third gen hub to or did you buy the hub from Tobin? I picked some up at the junkyard and I am going to take them to the machine shop.
      Stephen
      I got the kit off of http://www.flynbye.com/
      Great kit, same with everything to run these brakes and it wasnt over the top expensive..
      Jun 2009
      Central FL
      Sweet Jesus, they have some nice prices.
      Dan
      1968 Camaro v2
      Jun 2009
      Central FL
      Hey, would you recommend new hubs? They seem to be priced great and just in my range, I'm considering it now, only thing I'd worry about is the lugs not matching up. Do you know the thread size/spacing and length of the studs?
      Dan
      1968 Camaro v2
      The factory studs for that setup is what I posted earlier, but shorter by .50.. So that would make them 2 inches long.. As for the lug pattern, it is the same as any Chevy Passenger Car lug..
      Jun 2009
      Central FL
      They offer factory conversion and ARP studs, the factory ones are what you bought and are 2"?
      Dan
      1968 Camaro v2
      Yeah, that is what it came with.. You could get it how every you want it.. Just give him a call, he is a great guy..
      Jun 2009
      Central FL
      I plan to on Monday, thanks for the link man. Those ebrake cables look pretty good, too, if I can't get the stock LS1's to work.
      Dan
      1968 Camaro v2
