    Page 54 of 60 FirstFirst ... 4 44 49 50 51 52 53 54 55 56 57 58 59 ... LastLast
    Results 1,061 to 1,080 of 1184
    1. #1061
      Maryland
      Quarter panel molds are made, now finally on to the car. See if I can finish some of the bottom stuff, and send it to the powder coater.
      Ron Schwarz
    2. #1062
      Maryland
      Got the last of the cage work finished, starting on tin work, filling in the little windows 1 at a time.
      Ron Schwarz
    3. #1063
      The Netherlands
      Country Flag: Netherlands
      Looks great Ron!
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
    4. #1064
      Feb 2012
      Central NY
      Wow that's quite a jungle gym!
    5. #1065
      Jun 2012
      Australia
      Country Flag: Australia
      How are you intending to hold all the little sheet metal pieces in place?
    6. #1066
      Maryland
      Silicone bronze
      Ron Schwarz
    7. #1067
      Indiana
      Silicone bronze
      Are you going to leave it natural or paint over it? Either way, cool!
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
    8. #1068
      Maryland
      The body unbolts on this car, the chassis floor and all will be sent to the powder coater. The body may be as well, haven't decided yet. I will fill the voids in the floor with 1.75" rigid polystyrene insulation board, super light, and will make the floor flat. Then I will have some snap in carpet put on the flat part of the floor, like a boat.
      Ron Schwarz
    9. #1069
      Oct 2014
      Cage work looks fantastic. This is a lot of fun to follow along with Ron. Thanks for all the detailed pictures/explanations. Such a cool build.
      1988 Mazda RX7 - Forged LS/T56, 76mm turbo, ProEFI, Ford 8.8 - Sold
      1965 Mustang Coupe - TT Coyote, TR6060, Haltech, big brakes, updated suspension.
      2007 Aston Martin V8 Vantage - Full bolt-ons
      2016 BMW 428iX GranSport - Stock...ish.
    10. #1070
      Jun 2009
      New Hampshire
      Hey Ron, you have a tubing bender? Was wondering what you used to bend the cage and such. Thanks!
      Matt
      Matt from NH
      70 Camaro
      Project Wicked Pissa https://www.pro-touring.com/threads/...t-Wicked-Pissa
    11. #1071
      Maryland
      I use a JD squared hydraulic/pneumatic bender, works pretty good.
      Ron Schwarz
    12. #1072
      Sep 2007
      Buford, GA
      I haven't checked in on this one in a while, glad I saw it pop back up! I'm looking forward to hanging out with you and seeing the car hopefully sometime soon!
      Adam
      Adam
      1985 S10 - LT1 + T56
    13. #1073
      Mar 2018
      ron, do you have any other pictures/info on how you mounted the body to the frame?
    14. #1074
      Maryland
      I first made inner rockers with plates and nuts welded to the inside, then welded sleeves into the perimeter frame for bolts to go through. I'm sure their is an easier less labor intensive way to do it. but it works pretty good. The only bad part is the cage swells out at the A and B pillars, so you have to spread the rockers a bit when taking the body on and off. It comes off surprisingly easy though.
      Ron Schwarz
    15. #1075
      Indiana
      Ron, when you're done and the car is drivable, will the body still be removable or is this just to facilitate the build process?
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    16. #1076
      Maryland
      It will always come off, it bolts across the tail of the car and along the cowl. The way I seem to change things up, I like the ability to remove it..............who knows Pro Street could come back. LOL
      Ron Schwarz
    17. #1077
      Indiana
      Ok cool. I'm in the process of removing the Chevelle from its original frame for test fitting on the new frame. Since I have to rebuild the entire floor and finish the cage, I was thinking about how to make the body removable - just for the build - and then permanently attach it.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    18. #1078
      Maryland
      In that case I would have made the chassis the same width as the rockers, and slip it on and welded away.
      Ron Schwarz
    19. #1079
      Indiana
      I'll see how things go as I progress but most likely my body won't be removable when it's done, it is a street car after all!
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    20. #1080
      Mar 2018
      ok thanks! so it looks something like this when assembled?
      Name:  rocker rail diagran.jpg
      Sorry if its obvious, i can not find much info at all on removable bodies.
