    Page 2 of 2 FirstFirst 1 2
    Results 21 to 33 of 33
    1. #21
      Aug 2013
      You recall what the turbo manifold part number was for stainlessworks?? Also, how did you do you oil feed and drain? I was just going to t the feed but I wasnt too sure about the drain.
      Zak
    2. #22
      Mar 2013
      I don't remember the part number but I only think they make 1 high mount set for the LS. I got mine unwelded so I could fit them the way I wanted. My oil feed is a -6 that tees into two -4. I drilled and tapped the bolt on piece above the oil filter and installed the fitting. The returns are -8 with fittings welded into the oil pan. The returns are super important that they go down hill the whole way. I definitely would not tee the drain either.
    3. #23
      Aug 2013
      Cool man, I appreciate the help. I was going to t the feed but not the return like you.. Just trying to source out the right manifolds first.
      Zak
    4. #24
      Oct 2007
      Union Mo
      Good luck at Scottsdale. Keep us posted. Thanks Eric
    5. #25
      Red Deer, Alberta, Canada
      what wheels are those?
      Matt
      Instagram: Cst_koon
    6. #26
      Apr 2013
      Burleson, TX
      I believe they're Forgestar wheels. I'm sure he'll chime in when he gets back from kickin ass in Scottsdale. Talked to him earlier and he said the track out there is a series of drag races. Should be fun as hell in a car capable of 1000+ hp. Makes me so damn anxious for him to finish my car.
    7. #27
      Mar 2013
      1967 camaro 427 twin turbo project
      They are Forgestars. The car is working great this weekend. The cars and drivers out here are so fast it is unbelievable!
    8. #28
      Nov 2013
      Here is the Link to a vid I put together of the 67 lapping at a "damp" Eagles Canyon Raceway Toy Run.
      http://www.youtube.com/channel/UCyO7_0v9vRU21CUmY6LMKXg
    9. #29
      Aug 2013
      Question for ya, how did you or where did you run your driver side downpipe? Just from the looks of my engine bay i dont think Ill be able to run the frontrunner ps reservoir and have the downpipe in that same area.
      Zak
    10. #30
      Mar 2013
      I took the reservoir off and used a remote one from billet specialties. It required welding a fitting on the pump which was somewhat of a challenge to get air tight welding to cast! If I had to do it over I would probably change the pump.
    11. #31
      Feb 2014
      As if I didn't need anymore inspiration to build a TT for my 68... haha, wow. This is one seriously badass ride man. Thanks for the link for the videos!
    12. #32
      Socal, Ca
      Quick bump.
      How does the car do with water, oil, and IAT on the race track? With the turbos under the hood, I assume the car would over heat.
    13. #33
      Very cool car. Saw it compete at LSfest a year or two ago.
      Nathan Shaw
      71 Nova, 1000+whp 5.3, 8 second autoXer.
