    Results 1 to 11 of 11
      Apr 2008
      pictures of first gen camaros with ls1 turbo swaps?
      I'm not sure if its the right section or not, but i'm just looking for some different ideas on how to fab up my setup.
      I got a 67 camaro I just put a LS engine into and just got done mounting the intercooler, was wondering what people did with setting up the turbo's
      thanks!
      May 2008
      Staten Island, New York
      Ive done several kits for Camaro's and 3rd gen Nova's. The basics are you take a pair of LS truck manifolds and chop and cut them, add some sch10 pipe as needed, and weld some vbands to the ends. A Trailblazer manifold fits the left side a little better around the steering shaft. I angle mill the flange 5.5degrees to get more clearance around the box. Make a crossover and add a wastegate after the merge. A single is easier due to the limited room for a downpipe around the steering box and column. If you have to run twins, run the manifolds upside down and chop them up to run forward. Yes, you could make headers for a little more bling but its hard to beat the durability of cast manifolds and they are pretty hidden when its together and spark plug access is stock like.
      Here is my 71 Nova. This is the second turbo setup its had. I do all sorts of events with the car and I absolutely love the boost. It makes around 850 to the wheels.
      Here is a single kit I did on my 69 Camaro mock up car.
      And a pic of the left manifold.
      And the pair of manifolds.
      Nathan Shaw
      71 Nova, 1000+whp 5.3, 8 second autoXer.
      Aug 2011
      http://calgary.kijiji.ca/c-cars-vehicles-classic-cars-1969-Camaro-6-speed-LSX-700-hp-turbo-W0QQAdIdZ465949093
      Here is another one I did this week with a Precison PT88.
      Nathan Shaw
      Oct 2012
      British Columbia
      Very nice and this is on my list of future wants
      Todd
      '14 ZL1, 6 speed and 6.2L of Super Charged Awesome!
      '67 Camaro SS in process. A long, slow, expensive trip...
      How hard can it be...
      Project Obsession
      https://www.pro-touring.com/showthre...ject-Obsession
      Apr 2008
      progress so far today, got the intercooler and oil cooler rouged up
      awesome $250 ebay intercooler and a factory 98 range rover oil cooler i found sitting around
      perks of owning a junkyard!
      Make sure to use the absolute biggest radiator you can fit. With the oil cooler and intercooler out front, the air will be pretty warm by the time it goes though the radiator.
      Nathan Shaw
      Oct 2007
      Shawnee, KS
      Nathan,
      On a budget setup with the manifolds, what do you figure you have in the complete turbo setup? Is there a factory turbo you would use or do you prefer an aftermarket one?
      This is something I want to do down the road and will start collecting parts. Your installs look really clean.
      Subscribed.....
      Shannon
      67 Camaro - Finally getting to BUILD it.
      Camaro Build -> HERE
      Our Drag boat blog and videos HERE
      Apr 2008
      it is not cheap at all
      think up everything you could possibly ever need
      then double it
      Quote Originally Posted by 67CamNKC View Post
      Nathan,
      Subscribed.....
      Oct 2007
      Shawnee, KS
      I figured as much. I'm trying to get mine driving first, then phase 2 will be more power.
      Shannon
