Results 1 to 11 of 11
    Apr 2008
    Default pictures of first gen camaros with ls1 turbo swaps?
    I'm not sure if its the right section or not, but i'm just looking for some different ideas on how to fab up my setup.
    I got a 67 camaro I just put a LS engine into and just got done mounting the intercooler, was wondering what people did with setting up the turbo's
    thanks!
    May 2008
    Staten Island, New York
    Default
    Ive done several kits for Camaro's and 3rd gen Nova's. The basics are you take a pair of LS truck manifolds and chop and cut them, add some sch10 pipe as needed, and weld some vbands to the ends. A Trailblazer manifold fits the left side a little better around the steering shaft. I angle mill the flange 5.5degrees to get more clearance around the box. Make a crossover and add a wastegate after the merge. A single is easier due to the limited room for a downpipe around the steering box and column. If you have to run twins, run the manifolds upside down and chop them up to run forward. Yes, you could make headers for a little more bling but its hard to beat the durability of cast manifolds and they are pretty hidden when its together and spark plug access is stock like.
    Here is my 71 Nova. This is the second turbo setup its had. I do all sorts of events with the car and I absolutely love the boost. It makes around 850 to the wheels.
    Here is a single kit I did on my 69 Camaro mock up car.
    And a pic of the left manifold.
    And the pair of manifolds.
    Nathan Shaw
    71 Nova, 1000+whp 5.3, 8 second autoXer.
    Aug 2011
    Default
    http://calgary.kijiji.ca/c-cars-vehicles-classic-cars-1969-Camaro-6-speed-LSX-700-hp-turbo-W0QQAdIdZ465949093
    Default
    Here is another one I did this week with a Precison PT88.
    Nathan Shaw
    Oct 2012
    British Columbia
    Default
    Very nice and this is on my list of future wants
    Todd
    '14 ZL1, 6 speed and 6.2L of Super Charged Awesome!
    '67 Camaro SS in process. A long, slow, expensive trip...
    How hard can it be...
    Project Obsession
    http://www.pro-touring.com/showthrea...ject-Obsession
    Apr 2008
    Default
    progress so far today, got the intercooler and oil cooler rouged up
    awesome $250 ebay intercooler and a factory 98 range rover oil cooler i found sitting around
    perks of owning a junkyard!
    Default
    Make sure to use the absolute biggest radiator you can fit. With the oil cooler and intercooler out front, the air will be pretty warm by the time it goes though the radiator.
    Nathan Shaw
    Oct 2007
    Shawnee, KS
    Default
    Nathan,
    On a budget setup with the manifolds, what do you figure you have in the complete turbo setup? Is there a factory turbo you would use or do you prefer an aftermarket one?
    This is something I want to do down the road and will start collecting parts. Your installs look really clean.
    Subscribed.....
    Shannon
    67 Camaro - Finally getting to BUILD it.
    Camaro Build -> HERE
    Our Drag boat blog and videos HERE
    Apr 2008
    Default
    it is not cheap at all
    think up everything you could possibly ever need
    then double it
    Quote Originally Posted by 67CamNKC View Post
    Nathan,
    Subscribed.....
    Oct 2007
    Shawnee, KS
    Default
    I figured as much. I'm trying to get mine driving first, then phase 2 will be more power.
    Shannon
Posting Permissions
  • You may not post replies
  • You may not edit your posts
