Page 8 of 8 FirstFirst ... 3 4 5 6 7 8
Results 141 to 151 of 151
  1. #141
    Feb 2013
    Ft Worth, TX
    Default
    I got the rest of the rest of the interior looking so nice that I had to do something about the door panels. These are the basic PUI unassembled panels because I'd like to design my own eventually. (I know the armrest doesn't line up and it bugs the hell out of me.)
    I also finished the front part of the console which houses a double din radio and hides the wires running along the transmission tunnel. The radio is a Pioneer with Apple CarPlay and a very minimalist design. The slim design of the display matches the Speedhut gauges really well. I added LED footwell lights that are tied into the dome light circuit as well. I had used the same method to add lights to my Silverado and I think they make a huge difference in the perceived "quality" of a vehicle's interior. You may also noticed that I dealt with the poorly fitting carpet. I glued non-backed carpet to the sides of the tunnel and it tucks under the console/floor carpet. The formed carpet is trimmed along the base of the tunnel though it needs some sort of welting sewn to the edge.
    1970 Chevelle: 6.0 LQ4, T56, Strange 9 Inch, Ridetech Coilovers, LS1 Camaro brakes
    2004 Silverado 2500HD LLY/ZF6
  2. #142
    Feb 2013
    Ft Worth, TX
    Default
    I moved all of my photos to imgbb.com so now I need to relink all the pictures. It's going to take me a while so if someone wants to see a specific post let me know and I'll go back fix it quick.
  3. #143
    Feb 2013
    Ft Worth, TX
    Default
    Alright, I finally got all of the pictures updated. I started active duty at the end of July so it'll be a little while before can get more work done on the Chevelle. The next project will likely be upgrading the front brakes with 4 or 6 piston Brembo takeoffs and larger wheels/tires. I'll try to be better about posting pictures when I start on that.
  4. #144
    Nov 2002
    Wichita Falls,TX
    Default
    Dave, you going to be around for Goodguys?
  5. #145
    Aug 2008
    Default
    David, Just want to thank you for taking the time to update all of the links. This is probably one of my favorite builds, and I use your build as inspiration for mine.
  6. #146
    Jun 2013
    Default
    Incredible work! Thanks for sharing!
  7. #147
    Feb 2013
    Ft Worth, TX
    Default
    Thanks for the kind words, y'all. I've learned so much from the forums so I'm happy I can give something back.
    Quote Originally Posted by USAZR1 View Post
    I'm stationed in Ohio so unfortunately I won't be at the Lone Star Nationals. I'm going to try to make it to the Columbus Goodguys and LS Fest though.
  8. #148
    Mar 2015
    FL
    Default
    Wow! amazing. Love to see these types of builds.
    -Mitch
    G8 GXP, White Hot, Auto, bone stock
    68 Firebird, 428 Pontiac, CNC'd KRE Al d-ports, hyd roller, EFI, TKO600, TCI Eng complete chassis, Ridetech, Kore3 C6Z brakes, C5Z 18" with 315 rivals x4, C6zr1 mufflers
    RRR, NASA HPDE https://youtu.be/DPp1l9-FuNE
  9. #149
    Feb 2016
    ohio
    Default
    Amazing build just read the whole 8 pages! Makes me see where I'm heading with my 67 chevelle. Thanks for the good read!
  10. #150
    Default
    Wow, very nicely done and your car turned out fantastic. I think I have made my decision on painting the car now vs. spraying some epoxy. Very sinister look.
    Question: What brand did you use for the switch back marker lights? I want to do that exact same thing for my lower RS turn signals.
    New Project: 1968 Camaro 6̶.̶0̶ 5.3 w/ Z06 cam and 6 speed project
    1976 T/A LS1, 6 Speed, C5 front brakes, and etc. SOLD
  11. #151
    Feb 2013
    Ft Worth, TX
    Default
    I can't remember if I ordered them from ebay or amazon but I'm pretty sure they came directly from China. superbrightleds.com sells some as well that may be a little higher quality but mine have lasted so far. There are two types of switchback so make sure you order the one you want. One type simply flashes white and amber when the signal is on and the other (the type I have) turns off the white light and then flashes the amber on and off like a new Audi with LED DRLs.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
