      Oct 2011
      Tampa
      First gen Camaro brake line routing diagram or photos
      Hello -
      I am very close completing my front disc conversion from Inlinetube. I am attempting to connect the front hard lines to the caliper hose, however, they are 1-2 inches from lining up properly at the connection point.
      Is there a resource I can reference how the lines should be placed and connected? I took a look at a friend's original 1969 Z28 Camaro, but his routing is not the same as the lines that are included in my kit. (his hardline - flex line connection is made on top of the subframe, my lines seem to indicate the connection will be on the side of the subframe).
      I attempted to call inlinetube, but the only advice I can get out of them is that their kit follows a stock set up. However they do not include photos or instructions. I seem to be on my own on how to install their product.
      Other than wait for the next local car show, I could re-bend and re-flare the lines, but at this point I am assuming I am simply not installing them properly.
      Jan 2010
      Northport NY
      Post a photo of how you ran yours. I used inline tube SS lines and had no problems. Manual or Power brakes?
      Oct 2011
      Tampa
      Does any of this seem out of place or incorrect? I also have a couple of line clips left over from when I removed them, but no bolts. If there is a routing issue, I'm assuming its centering around the silver bracket.
      I am running power brakes.
      Chicago suburbs
      I had a similar issue with mine. Redo the brackets- it will be easier. Lines look close enough to bend into shape by hand. The rock guard will help prevent kinking, but be careful
      Oct 2011
      Tampa
      After talking more with inlinetube, I am going to grab a tube bender and hopefully get these lined up and full of brake fluid this weekend.
