    Results 1 to 9 of 9
      Jul 2007
      nw phx
      Which head gasket to use?
      489 (.030) zero deck, aluminum heads, 6200 max rpm aprox 10:1 depending on thickness of HG..
      FelPro 375-1037 has been suggested. Iron block, aluminum heads..
      MLS? This is a street motor, not boosted, no nitrous.
      Everyone seems to have their opinions on what to use, block/heads not o-ringed.
      Thanks for any suggestions.
      ...life is too short, live for today, tomorrow isn't guaranteed
      Jul 2007
      nw phx
      40 views and not any comments?
      May 2010
      Mooresville, NC
      I ran the FelPro 1037 on my 496 BBC and never had any problems. My engine specs were almost identical to yours.
      Marc Battiste
      1969 Camaro
      LY6/T56/12 Bolt
      Jun 2006
      Katy,TX
      If the head and deck surface are smooth enough it is hard to go wrong with an MLS like a Cometic, but I would bet a plain FelPro type would be more than adequate unless you need extra thickness you can get(0.051 etc) from Cometics.
      1965 GTO project car
      2004 Pulse Red GTO
      Nov 2012
      ST. LOUIS MO
      I use cometic, with nitrous, without, 13 to comp. No problems!!!!
      Oct 2012
      British Columbia
      I also used Cometic just in case I decide to add some NOS at a later date to catch a couple of those LS cars. Just an FYI if you can find some Mr.Gasket head gaskets they are made by Cometic and are half the price. At least they use to be.
      Todd
      '14 ZL1, 6 speed and 6.2L of Super Charged Awesome!
      '67 Camaro SS in process. A long, slow, expensive trip...
      How hard can it be...
      Project Obsession
      https://www.pro-touring.com/showthre...ject-Obsession
      Folsom, Ca
      I ran fel pro's until my boosted motor popped one, Now I run Cometic MLS and never had a problem. Boosted or not I would run these gaskets. I found Cometics restamped as trickflows as well, similar to what Todd ^ above me said.
      Nov 2012
      ST. LOUIS MO
      I use cometic. No problems
      Jul 2007
      nw phx
      ...i've had felpro on it, havent had an issue in 7 years
