    Results 1 to 20 of 27
      Independence,IA
      What would be the best pro tour rear suspension?
      I have 86 Cutlass that I am starting to Pro Tour. I have bought a different frame to start on. I was going to convert the rear over to a Torq arm with a watts link. Just wonder what you guys thought of that.
      Jun 2012
      South Lyon, MI
      You cannot go wrong with that set-up as long as it is dialed-in correctly.
      Are you planning to buy a kit or build it yourself? Will you be using the stock lower control arm mounting locations?
      Independence,IA
      I am planning on doing it all myself. I don't know if I will use the stock lower mounts. I 'm not sure how well they will work.
      san diego
      I like my 3-link with watts
      Jun 2012
      South Lyon, MI
      Quote Originally Posted by williecutlass View Post
      Do you have any way to lay it out and run some calculations? The load should not be more than the stock set-up depending on where you tie into the rear axle. You could change to links with spherical rod ends to eliminate the rubber bushings. Just don't use solid bushings that will restrict movement and cause binding.
      This sounds like an interesting endeavor. I will be interested to see photos of your progress.
      A three link like Bryce has is also a good option. It may cause more cutting on the floorpan than the torque tube, but can be lighter and can perform real well when set up right.
      Lawrenceburg, TN
      thats the age old question that keeps driving this site! if you ask 10 guys you get 10 differant answers, I have driven 4links, 3links, leaf spring, truck arm and Independent rear suspension cars and have liked them all each has its own attitude, and its all about the fine tuning on each, at an event last year, I was just as fast on the track driving a 4link car as I was driving a leaf springed car during a driving demo
      Indiana
      Ultimately...there are better suspension designs than the GM factory 4 link. In reality...that design will outperform MOST drivers, even in a competitive autocross or road course environment. If you are looking for the most bang for your buck [like most of us]...start with some revised front suspension geometry, better tires, better steering box, good shocks, improved seats and steering wheel, and some good front brakes. After you've optimized all those areas, THEN start thinking about revising the rear suspension. As Rodney said, all the various suspension designs feel a bit different...but none of them are THE clear winner. If they were, there would be no question.
      As usual...just my opinion.
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      Independence,IA
      I do plan on 13" front brakes, rack and pinion, after market front control arms, air ride, different front spindles,19x9.5 with a 255-35-19 front 19x11 with 295-35-19 rear wheel tire combo.
      I have already replaced the side frame rails with 2x4 rec. tubing and was going to start modding my rear part of the frame.
      Southern Indiana
      Honestly for the cash, the factory style triangulated 4 link with johnny joints and air ride and double or triple adjustable shock would do pretty much anything you want, second choice would be use lower mounted control arms, a third upper link in two parallel uppers and a Fays2 Watts link.
      I just dont understand the infatuation with torque arms. That is the one piece of garbage I am TRYING to eliminate from my Monza as it takes up so much real estate AND over stresses the tranny.
      Anyway. Try not to let a credit card design your suspension, keep it simple and straight forward.
      Lee Abel
      AFTERMARKET PERFORMANCE
      May 2002
      Northern California
      Torque arms are great for ease of installation and packaging.
      Other than staying and modifying your 4 link going to a center third link would be very easy. With the proper legnth upper link you will loose some back seat area.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Oct 2009
      New Derry, PA
      Lee, a torque arm probably gives the best compromise between acceleration and braking torque reaction, while still maintaining good rotational freedom for the axle (if designed properly). I'll agree that the factory piece in your Monza is probably junk, designed to be the lowest cost to produce... And they don't stress the trans at all when mounted to a frame crossmember.
      As Bret stated, any typical rear suspension design will probably be better than the driver in 90% of situations. Any suspension needs to be correctly engineered and installed, but for a beginning builder, the torque arm eliminates a lot of "figuring out" from the process, with no real down side in performance.
      Southern Indiana
      Ray have you ever seen the torque arm on a Monza? forerunner to the third gen F body and still took aftermarket to keep it remotely useful as the stock crap was pure junk with power. Also under a smaller car it takes up useful room to fit things like , oh say exhaust. After trying to like it, trying to use them I decided to run my yellow Monza with swing arm suspension and then decided after going PT style I will make a bolt in 3or4 link upper mount to do away with it completely and the panhard bar and use a watts link. Why, because its gonna handle better ,take up less critical room and for me, the tuning of it will be so much better than a torque arm. Just cause it can go down road doesnt make it any better. It just makes it functional in SOME cases.
      Kind of like 4 link versus ladder bars. Had them both, not BIG fan of ladders as they do go straight ok, tuning and handling, not so good, Took Jegster SS bars to make me rethink trying them again, but again undercar real estate on my car is limited so passing on that.
      Kind of like the guy who got on here and bashed Hbody front end design YET I see big name companies selling Mustang II crap as performance. YET thousands buy them and design parts around them, oh and he cut up a car to build a new frame/suspension. Seemed like a waste but then it is his car so he can do what ever. Me I will make minor modifications to make what I have work better. Didnt seem to hurt IMSA Monza's. As the 4 or 5 I have seen had no mods made to the mounting points in front.
      Again I may just be jaded, seen too many things made complicated, hard and just plain not built right, too supposedly make it better.
      Lee Abel
      Independence,IA
      All in all I just want to get the best bang for the buck right of the bat. I don't want to put this new frame together and two years latter tear it all out for something that works better. I've done that before. Cost more money in the long run.
      Independence,IA
      Just wanted this to go as good as my last build. Here are a couple pics. O yah if anyone has see it around Iowa let me know, had to sell it awhile back. Kind of lost track of it.
      Nov 2012
      i'm not a fan of the torque arm,but if thats what you want its hard to do it yourself cheaper and as painless as the bmr kit. of course i dont know if they have a kit for the cutlass.
      i still think the best bang for the buck is a triangulated four bar and coil overs. no need for a watts or pan hard, saving time and money. you would have to really drive that to feel any of its limitations. honestly you will likely be limited by your non-floating rear before the suspension. id get a full float before i spent more on the pt suspension
      Independence,IA
      I am plaining on building a 9 inch. Would you say 4 link is better than a torq arm?
      Lawrenceburg, TN
      the answer is whats best for you, I would look at pakaging issues, for example, a DSE 4 link comes thru the floor do you want to cut up your car, ridetech four link fits without cutting but you have to weld on the rear axle, the torque arm is larger and requires extra bracing on the frame and some welding on the frame for a watts or panhard, so whats best for you?
      Independence,IA
      Welding and fab. work will not be to much of an issue. I spent 6 months welding up semi trailers and have just spent the last 5 1/2 years as a cnc machinist. I just want to get the PT performance from the get go. Don't want to have to change thing after a few years.
      WOW..... not sure where to start. So many good bits of advice and opionions here. We do have alot of Torque Arm experience with 82-02 F-Bodies which is why we came up with a Torque arm to replace the 67-81 F-Body - 68-74 X-Body leaf spring suspensions. We make parts for over 18 different platforms now and we could have easily put together a 4-link or 3 link with a panhard bar, but we decided on a Torque Arm/Watts link for the leaf spring cars.
      Now the elephant in the room is do we make or plan to make a Torque Arm for the 64-72 A-Body & 78-88 G-Body cars???? The verdict is still out, but the reason we have not committed to developing a system is will it VASTLY improve the performance of those cars?
      I think that although you can experience some binding with the suspension in your car it is a proven performer with the right aftermarket components in place which obviously we manufacture.
      Independence,IA
      The torque arm setup seam to work well on the gnx's. Just thought with a little upgrade like the watts link would make it better.
