Results 1 to 1 of 1
Thread: 67 Camaro
    Aug 2003
    Byhalia, MS
    Default 67 Camaro
    I have decided to put my project car on the market
    Details:
    67 RS car. It is an early build. Bolero Red with black vinyl top. Factory console with gauges and tach. Black deluxe interior. Tinted windshield. Interior bright trim. Big ole bumper guards. Powerglide car with 12 bolt rear. 4 wheel manual drum brakes. All of which has been changed for a more modern setup, except the 12 bolt.
    First was rust repair...
    Dash top
    Toe boards
    LH and RH floor boards
    Center trunk pan
    NOS outer wheel houses
    NOS quarters
    Patch lower corners of front fenders
    NOS header panel
    I built a rotisserie and finished all the welds and sandblasted the majority of the car. I then finished the bottom all the way up to high build primer.
    It took me several years working on the car every now and then to get all the above done. I then got burned out on the car and it sat for a few years with very little progress made.
    Flash forward to today...
    I had a friend build me a 4L60E trans with all upgraded internals. It will be utilizing the Baumann Optishift trans controller.
    I had so many new SBC parts laying around that I scraped my LS1 build and put together a 450 horse SBC 350.
    I put all new bearings and new Moser axles in my factory Eaton posi, 3.73 12 bolt rear diff with a 'Jegs' aluminum diff cover. Need to find someone to weld up the tubes.
    I recently purchased the Ridetech AirBar with their new single adjustable coilovers.
    Speedtech ATS Chicane front coilover mounts for the stock subframe.
    Ridetech upper and lower control arms
    DSE 600 steering box
    Ridetech Tru Turn setup
    DSE subframe connectors
    DSE firewall fill plate
    DSE mini tubs
    Vintage Air Gen IV hvac setup with billet controller
    Custom center console modeled after the 67 original gauge console, but with an arm rest and cup holder
    Lokar billet 6" shifter
    Lokar LED shifter display bezel with boot
    2000 Trans Am front electric leather seats
    Billet steering wheel
    Cheesy Ebay aluminum radiator
    LT1 electric fams
    Spal PWM fan controller
    PI Vigilante 2600 converter
    B&M trans cooler
    -AN fittings
    SS hardlines
    Wilwood 13" 6 piston front brakes
    Wilwood 12.19" rear brakes
    G-Force transmission crossmember
    EMS billet hood hinges
    EMS billet trunk hinges
    EMS billet tail light bezels
    Hotchkis front sway bar
    LED tail lights and 05 Grand Am LED center brake light. Will be inserted in rear spoiler
    AAW Classic update wiring harness
    18" C6 Z06 Motorsports wheels
    Nitto NT 05 tires
    There's lots more. Just too much to list
    A literal steal at $28,500...Serious inquiries only please and NO, I will not part the car out. My email is jebcamaro67@yahoo.com and my phone # is 901-four 8 six-zero 3 5 zero
    Link to build thread...http://www.lateral-g.net/forums/showthread.php4?t=35882
Posting Permissions
  • You may not post replies
  • You may not edit your posts
