    DE
    Default 3 Point Retractable Seat Belt Mounting
    Hello everyone. Looking to try and get some ideas on mounting a 3 point retracting seat belt in my 69 Camaro.
    The car is currently at the body/chassis shop and will be getting a roll bar in it (6 point). I know Morris Classic has a nice setup, but the one thing I don't like about it is the way it mounts in the back over the rear window and then hangs/reaches across the window/roof area to the front seat. So since I am getting the roll bar installed, I was thinking of mounting it to the bar itself similar to what Vegas69 has (pics of his attached).
    Does anyone have any experience with different setups?
    I know Corbeau has a setup:
    http://corbeau.com/products/seat-belts/
    And Morris has theirs, but not sure if it can be mounted to the roll bar instead.
    Any experience with different setups or recommendations?
    The car will have a 4 point harness too, but will probably not be used all the time on the street.
    So Basically, trying to do a setup similar to the pics below (Vegas69's car). Thanks for any help you might have!!
    69 Camaro - G-link, 12 bolt Moser, Speedtech CA, Iforged wheels, LS2, 6spd, etc. etc. In-Progress...
    www.fquick.com/jim98ta
    Default
    We have a 3 point seat belt that will mount to a roll bar.
    Our seat belt has a longer lanyard that decreases the angle
    across your neck.
    Billy
    Morris Classic Concepts
    DE
    Default
    Billy,
    Thanks for the response!! Do you have any pics or pricing on your setup? Don't see it on your website.
    Default
    The Roll Bar set has a very short soft Lanyard , it bolts to the Roll Bar Bracket.
    The Roll Bar set would be the $300.00 per set, GM Mark of Excellence $330.00
    Thank You, Billy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
