    Page 2 of 2 FirstFirst 1 2
    Results 21 to 28 of 28
    1. #21
      Sep 2011
      Lake Ozark Mo
      Had same type issue couple years ago. Check ur push rods. Had 2 that didn't have the oil holes opened up. One more thing is 35psi is a little low for a SBC isn't it? Normal is 40-45 from my experience. Something else is check the oil pump pickup. Seen them little lose and will leak oil around pickup tube.
      Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
    2. #22
      O.K. so what did you find?
    3. #23
      Dec 2009
      knoxville, tn
      we still have not found anything definitive.
      Tom Hensley
      69 ss/rs clone
      98 ta ragtop
      "attack life....it's going to kill you anyway."
    4. #24
      Jul 2012
      I quickly scanned the thread, but is the converter/transmission new. When a converter is new and the transmission is low on fluid it can have a knock to it. Had that happen once. Just trying to think outside the box
    5. #25
      Sep 2012
      I hope that you are not having the same issue I did, but my conversion motor-mounts allowed about 2 inches of play and shifting into gear caused the torque to pull the engine closer to the firewall and the distributor pushed up causing it to ride hard and click.
    6. #26
      Feb 2011
      So CA
      Tall or short valve covers. Depending on lifter pump up could the rockers be hitting the oil filler baffle?
    7. #27
      Feb 2011
      So CA
      Quote Originally Posted by jbake View Post
      Some sbc's have as little as 10 psi at idle. 35 is exceptional.
    8. #28
      Chicago suburbs
      Are you sure that it is an engine noise? Can you narrow it down with a stethoscope?
