    Aug 2012
    va
    Default power injection 3
    For sale is my power injection 3 TBI system it is the base satin kit which retails for $1,300 my lost your gain. I have little over $1,400 in the system it will come as seen in the picture with a liquid PSI gauge installed on the fuel log and a summit return line regulator. I will also throw in the EFI fuel pump and a -6am fuel line that was used as the return. The wire harness had been length from this picture to reach the battery, fuel pump and ing power. The O2 sensor is also goes with a the system only thing missing is the weld in bung as its welded to my lead pipe. The system has three hours of run time on the ECU $1,000 obo if anyone would like video of the system running I can post one of the if. It's idea for a tuner or someone that has the time to mess with it brought it in early spring also have the software for the 2.01 dash board software for the 3.0 is out but will not work with the current ECU. email robert_king2001@yahoo.com
    Aug 2012
    va
    Default
    still available
    Sep 2009
    Default
    I might be interested. PM'ed
    New Project: 1968 Camaro 6̶.̶0̶ 5.3 w/ Z06 cam and 6 speed project
    1976 T/A LS1, 6 Speed, C5 front brakes, and etc. SOLD
Posting Permissions
  • You may not post replies
  • You may not edit your posts
