    Page 2 of 2 FirstFirst 1 2
    Results 21 to 27 of 27
    1. #21
      Central CA USA
      I got some large head bolts from Summit Racing, I think they were Mr Gasket. The first set with small heads were Raetech brand on a new Eaton Positraction install.
    2. #22
      North Carolina
      Is there any reason someone couldnt just use grade 8 bolts with hardened washer's?
      1969 Chevy Camaro
      D&D T-56, 04 LQ4
    3. #23
      Aug 2005
      Hamilton, NJ
      LH thread?
      Scott from NJ.
      Vent Windows Forever! ...
    4. #24
      North Carolina
      Looking at them in the McMaster-Carr catalog right now.....
      1969 Chevy Camaro
      D&D T-56, 04 LQ4
    5. #25
      Central CA USA
      What size heads? 5/8" is a standard head for a 7/16" bolt, you need larger.
    6. #26
      North Carolina
      Gotta check again, tomorrow at work. I'll let you know.
      Curious, whats the theory behind the actual head size?
      1969 Chevy Camaro
      D&D T-56, 04 LQ4
    7. #27
      Central CA USA
      Look at the under head seat area of a 7/16" bolt with 5/8" head. It's .060" wide. Under use it will embed into the cast iron carrier & come loose, Locktite won't help. Larger head has more seating surface, or use a hardened steel washer, but be careful about bolt length if the washer is thick.
