Results 1 to 20 of 27
    Connecticut
    Default Ring gear bolts came loose
    So my car got towed home today. 3 of the bolts on the ring gear came out and were bouncing around. No damage to the gears thankfully, but as I checked the other bolts they are all loose.
    Question is: Can I put new bolts in and try it from there? Is there anything else I should look for?
    1969 Chevy Camaro
    D&D T-56, 04 LQ4
    Feb 2008
    Denver NC
    Default
    Safety wire them.... ARP Usually makes bolts that come pre drilled ..if not drill them yourself....
    Jul 2008
    Ft. Worth, TX
    If the gears don't have damage then throw a new set of bolts in with red loctite. Then check the wear pattern. Safety wire is a good idea but you have to take the carrier out. I have never had a failure from the ring gear fasteners backing out. I have only safety wired one set if ring gear bolts and that is the 9 inch carrier i am using now.
    Loganville, GA
    Default
    Carefully check the gears for any damage, if none then you should be okay.
    A buddy had two bolts back out on his Ford 8.8 with a loud bang. He was able to still drive the car, but when we pulled the cover, the bolts were a mangled mass and the ring and pinion both had broken teeth. It also took a chunck out the posi carrier as well.
    2012 Camaro SS LS3 6-spd
    2003 Suburban 2500 8.1L
    1975 MGB Roadster
    2003 GSX750F Katana
    Connecticut
    Default
    Well the gears the check out OK, I pulled each bolt out one at a time, cleaned it and the threads in the ring gear, used blue loctite and reinstalled the bolts. The cover was damaged by one of the bolts so I have to get a new cover before I can tell if everything is OK....
    Side note: Finding a dif cover for the orignal 8.2 is difficult. Anyone know of anyone making non-chrome repoductions?
    1969 Chevy Camaro
    D&D T-56, 04 LQ4
    Connecticut
    Default
    Just wanted to update:
    Got everything assembled and took the car out, everything sounds good! Thanks for the help guys...
    1969 Chevy Camaro
    D&D T-56, 04 LQ4
    Jun 2010
    Deployed
    Default
    Quote Originally Posted by 69importkilla View Post
    Did you initially put red loctite on the bolts? You usually dont see them back out.
    1970 Camaro/DSE build
    http://www.pro-touring.com/threads/1...71#post1147371
    Jul 2008
    Ft. Worth, TX
    Red loctite is used not blue.
    Jun 2010
    Deployed
    Default
    Quote Originally Posted by Chevelle598bb View Post
    +1
    You want those bolts to stay in place! Blue is for smaller diameter bolts.
    Central CA USA
    Default
    I had them back out twice with red loctite on an 8.5" rear axle. Found out the aftermarket bolt heads were 5/8", stock was 11/16" but I hadn't even looked at the old open carrier I pulled out. The 5/8" heads only have around .060" seat on them & they were embedding into the cast iron carrier & coming loose.
    I was told they would work if a hardened washer was used.
    Connecticut
    Default
    To answer, I never assembled the rear gears, I bought the car with the rear end as is. After removing the bolts, I did notice there was no locking compound on them whatsoever. I nstalled new bolts with hardened washers and blue loctite. I was weary of using red...
    Hey guys thanks for pointing out I should have used red loctite after the fact!!!
    Last edited by 69importkilla; 07-12-2012 at 03:19 AM. Reason: Spelling and additional comment
    1969 Chevy Camaro
    D&D T-56, 04 LQ4
    Sep 2008
    JACKSONVILLE, FLORIDA
    Default
    Quote Originally Posted by David Pozzi View Post
    Yep, on the cheaper gear sets, the bolts have smaller heads that will come loose. You can use a washer, but I prefer to use the factory bolt. It doesn't come loose.
    Craig Scholl
    CJD Automotive, LLC
    Jacksonville, Florida
    904-400-1802
    www.cjdautomotive.com
    "I own a Mopar, I already know it won't be in stock, won't ship tomorrow, and won't fit without modification."
    Jun 2010
    Deployed
    Default
    Quote Originally Posted by sccacuda View Post
    Seems very few if any have the larger head bolts anymore. I was lucky to find a guy who had NOS Mr Gasket bolts on Amazon.
    Aug 2005
    Hamilton, NJ
    Country Flag: Swaziland
    Default
    deja vu, the bolt issue just came up at nastyZ, same end result.
    http://www.nastyz28.com/forum/showthread.php?t=244801
    Scott from NJ. Stay thirsty, my friends
    Vent Windows Forever! ... My junk, featuring the Red Dragon ... NastyZ28 ... NJ Camaros & Firebirds
    Connecticut
    Default
    I just checked nastyZ and those pictures are identical down to the diff cover's damage to my car!
    1969 Chevy Camaro
    D&D T-56, 04 LQ4
    Jul 2008
    Ft. Worth, TX
    Default
    I did mention red loctite in an earlier post.
    Connecticut
    Default
    Ha! I noticed it "cough" after the fact....
    I have to practice my reading comprehension skills!
    1969 Chevy Camaro
    D&D T-56, 04 LQ4
    Jun 2010
    Deployed
    Default
    Quote Originally Posted by BonzoHansen View Post
    Ouch!
    Good thing I ran across Freddie's bolt warning years ago! I was very anal when I rebuilt mine. Those proper GM bolts are not that easy to find. Only a few seem to have them and they are a little pricey.
    Connecticut
    Default
    I'm curious about this GM bolt thing. Couldnt you just subsitute grade 8 fasteners with hardened washers??
    1969 Chevy Camaro
    D&D T-56, 04 LQ4
    Aug 2005
    Hamilton, NJ
    Default
    if you follow that link, freddie lists a washer he has used in a pinch. and those bolts are LH thread.
    "Any time that I use these bolts I put a hardened steel Ford washer under the head to prevent this from happening"
Posting Permissions
  • You may not post replies
  • You may not edit your posts
