      Jul 2012
      67 Camaro 6.2L LS3, 6 Spd auto, Big Brakes 500 hp Amazing driver
      This 67 Camaro is one hell of a driver with its 6.2L LS3 and 6l80 six speed electronically controlled auto out of a 2010 Camaro. The set up has under three thousand miles on it and had prevoiusly gone through a 90% restoration. C5 Corvette discs all around and a modified suspension. The build sheet is as follows
      1967 Camaro Parts List
      Engine
      GM LS3 6.2L 376 ci smallblock
      LGM G6X3 camshaft over 230 IN/ over 240 EX duration and over.600 lift
      Comp 921 dual valve springs
      Comp Cams pushrods
      Xcelsior Motorsports portedLS3 throttle body
      Xcelsior Motorsports portedLS3 intake manifold
      Katech single roller timingchain
      Moroso LS series oil pan #20141 with remote oil filter
      ARP head bolt kit
      Billet chrome fuel rails
      Street & Performance-chrome intake tube connected to custom 3” body matched xtension
      NGK #4177 spark plugs
      Hooker motor mount adapterplates #1261-HKR
      Energy Suspension motormounts polyurethane #3-1115G
      Turn Key coil pack coverspainted exterior color
      Billet Specialties- 16 lbradiator cap and 13”x2” overflow tank
      Mobil 1 5w-30
      Cooling/Electrical
      SPAL 16” #2082 true 2470 CFM
      Griffin aluminum radiatorSummit #GRI-1-55242-x
      DSE 7”headlight kit w/electric RS hidden headlights
      Speartech wiring harness formotor & trans. GM motor & transcomputers
      O2 sensor #12617332
      Billet Specialties Optimabattery relocation kit optima red topbattery 34/78
      Dakota Digital VHXgauges Carbon fiber back with blue LEDbacklight
      LED parking/driving lightsand dome light
      Fesler LED taillightconversion
      Starter #10465385 GMpart 1997-04 Vette & 1993-02 Camaro GEAR REDUCTION STARTER
      Transmission
      6L80 6 spd. Auto 2010 Chevy Corvette spec.
      Custom computer programmedshift points and line pressure
      LG Motorsports 2800 stallconverter
      2010 CTSV shifter
      Steel driveshaft with Spikeryoke # 3-3-1561KX
      Transmission cross member-stock 67 type flipped backwards with custom bracketry
      Transmission tunnel raised 2”in height to accommodate the taller 6L80 trans
      Transmission mount 2010Camaro
      Brakes/Steering
      Front- C5 Corvette with PowerSlot slotted cryo treated rotors
      Rear- C5 Corvette with PowerSlot slotted cryo treated rotors
      Hydratech hydroboost powerbrakes, shallow style master cylinder
      Perf. SteeringComponents(PSC) power steering remote reservoir 6”
      DSE power steering pump TypeII without reservoir. Polishedaluminum #090301P
      Lee Engineering 12.7:1 quickratio steering box and rag joint
      Fuel System
      DSE narrowed & baffled 17gal stainless steel fuel tank with 90 ohm sending unit
      Walbro GSS-340 in tank fuelpump
      91 octane
      -6 steel braided fuel lines
      AN fittings
      Exhaust
      Hooker Super Comp 1.75”ceramic coated headers #2288-1HKR
      Gasket- Mr Gasket MRG 5966
      3” piping with 2 chamberFlowmaster mufflers
      Quick Time Performance (QTP)electric cutouts- pair
      Suspension/Drive train
      Front- Savitske Classic &Custom FX spindles(7/8“ drop), SPC UCA’sadjustable for camber & caster,SPC LCA’s w/ graspable racing bushings
      Alston 16 position shocks setting 7 # VAS 14145-615
      Global West 1” lowering coils
      Hotchkis 1 1/8” hollow sway bar
      SPC coil spring spacer
      Rear- Leaf springs lowered 2”
      Helwig ¾” solid rear sway bar
      Sub frame connectors
      Cal Tracks traction bars
      Alston Varishock 16 position shocks setting 5
      10 Bolt rear end, posi 3.73
      Wheels
      Billet Specialties Fast Lane
      Front: 18x8 (4.5” BS) 235/40/18 Kumho Ecsta MX studs/lugs M12x1.5(Corvette hubs and brakes)
      Rear: 18x9.5 (5.5” BS) 275/40/18 Kumho Ecsta MX studs/lugs 7/16 (Camaro hubs)
      Miscellaneous
      DSE core support closeoutpainted exterior color
      DSE firewall block off plate
      Corbeau TRS front seats in black full leather (stockseats in storage)
      Corbeau black camlock harnessbelts
      OER center console withoutgauges. Gauges in dash
      Billet Specialties windshieldwiper post covers
      Billet Specialties rear viewmirror with bowtie
      Billet Specialties Fast Lanesteering wheel Black leather wrap/small bowtie horn button
      Billet Specialties blackanodized window cranks, lock knobs and door handles
      Ringbrothers billet hoodhinges
      Motor & trans raised 1.5”compared to stock 67 Camaro location to accommodate taller 6L80 transmission
      Paint is Indigo Blue off aChevy Tahoe est. 2002
      Frame off restorationfinished 2004. Frame sanded and paintedblack
      Vehicle weight withoutdriver 3340 lbs
      Original equipment
      Built 3rd weekof May 1967 in Van Nuys, CA. It was a V6 sport coupe in Mountain greenexterior with standard black bucket seats, center console and fold down rearseats. TH400 automatic with the RPO-Z22Rally Sport pkg. Body unit # 34617
      You Tube walk around
      http://www.youtube.com/watch?v=alyS_Eresrc
      Photos
      $69.000.00
      Dave
      Dec 2009
      Cleveland, TN
      Nice looking car! GLWS
      69 Camaro LS 6spd Kenne Bell, 69 SS MTI 427LS 6spd, 66Nova LS auto, 66Nova LS 6spd,55Nomad LS auto (Family Cruiser),2006 Viper (Daily),71PT Camaro project, 67RSSS LS auto project, 71Chevelle, 72Vette
      Mar 2010
      Alabama
      Does this car have stock wheel tubs? I would like my car to sit like this.
      David Butler
      "If you're not first, you're last"
      67 Camaro Twin Turbo SBC (changing from Blow-thru to Holley HP EFI)
      Jul 2012
      Bump
