06-22-2012 #1
12586242 PCM with custom tune (not stock)
$100 shipped lower 48 states
I have a custom tuned PCM that I was going to use in the swap in my old camaro, I have gone and a different direction and don't need now
PCM was tuned by lt1swap.com and here are the specs I gave him
* Based on a 5.3 engine, but using a LS1 Camaro intake and 5.7 injectors
* Remove all Emission and EGR
* Removed rear oxygen sensors (only will be using front two at exhaust manifold)
*Remove any VATS
* Transmission Type is 4L60e
* Keep Mass Air Flow sensor (you will need to use one the intake) The one you need is for a 99-07 silverado 15904068
* It has cooling fan controls programmed in, you may need to add the wiring on your harness if it didn't come with it. Fans are set to come on one at one temp, the other at another temp
This is a drive by wire PCM so you will need to make sure you have the pedal, throttle body and tac that corrosponds to this PCM number.
Other than whats mentioned above there are no other mods made to the tune, the cam settings and everything else are for a stock engine
Price includes shipping via usps priority mail anywhere in the USA
My build thread
http://www.nastyz28.com/forum/showthread.php?t=241037
Paint Jail Experience
https://sites.google.com/site/paintjail/home
06-27-2012 #2Sold!
My build thread
