Results 1 to 17 of 17
Thread: Paint on Bolts
    Nov 2009
    New York
    Default Paint on Bolts
    I hope to start painting my firewall and other engine bay parts over the next week and I know the trick to painting bolts by placing them in a piece of card board but what is the trick to not screw up the paint on the bolts during assembly?
    John
    IL
    Default
    Good luck, I have tryed everything from tape to 3M strip caulk to a bigger socket and paper towels pushed in. Door hing bolts were the ones that drove me nuts, ended up base coating them first then put the doors on and painted it just like the factory did with the fenders off. Your modern cars today are painted with most of the body panels on the car and bolted down so the paint on them looks great. I for one just use the blackend bolts this way I move them around all I want and not mess up any paint on them. Or you could use stanless bolts but those of coarse are more money. I would love to see what others have come up with, not saying it can't be done just saying it's hard.
    Rick
    Sep 2008
    JACKSONVILLE, FLORIDA
    Default
    I put them in the oven. My wife hates it. Use a good enamel paint, not lacquer, and don't hog it on, just enough to gain color. I bake them at 200* for 30 minutes. Let cool and serve.
    Craig Scholl
    CJD Automotive, LLC
    Jacksonville, Florida
    904-400-1802
    www.cjdautomotive.com
    "I own a Mopar, I already know it won't be in stock, won't ship tomorrow, and won't fit without modification."
    Nov 2009
    New York
    Default
    Quote Originally Posted by BadRS69 View Post
    Understand Rick, that is what I run into..
    Nov 2009
    New York
    Default
    Quote Originally Posted by sccacuda View Post
    Graig I may give that a try but I think I would use the outside grill
    Oswego il
    Default
    pick up a toaster oven at a yard sale or goodwill. perfect for bolts and doesnt take up much room
    Nov 2009
    New York
    Default
    Quote Originally Posted by indyjps View Post
    Even a better idea
    Oct 2005
    Independence mo.
    Default
    I have bought a set of sockets from mac tools that have plastic inserts in them. They seem to work pretty good so far they only have a torque rating of 25ftlbs though. Price is a little high unless you can get them on sale.
    san diego
    Default
    I am not a fan of painted bolts. Why not use stainless or good black oxide bolt.
    Nov 2009
    New York
    Default
    Quote Originally Posted by Bryce View Post
    The bolts I'm concerned about are the ones to hold the fenders to the firewall, I really want them to be same color as the firewall.
    John
    Near Dayton, OH
    Default
    I typically powder coat any of the bolts that I need black. Holds up pretty decent for at least the first installation. If you have to constantly remove them and reinstall then it can start scratching.
    I do this with all of the black oxide bolts as well. That coating doesn't hold up worth a crap unless you clear coat it or keep them saturated in oil. I have a few bolts that I forgot to coat and within a week being installing on my car and sitting in the barn the coating is completely gone and they are all rust now.
    ARP's black oxide coating seems to be a little better but most of those have started to rust as well.
    1987 Olds Cutlass Supreme FE3X Clone
    EFI455/T56/9" w/ 4.30 gears
    __________________________________________________ __
    Melbourne, FL
    Default
    Totally stainless has black stainless indented hex bolts that look like stock. Might check out their kits. They also have a great assortment of high strength ARP stainless alloy bolts suitable for suspension work.
    67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
    Honest dad that 455 on the side of the block is a serial number
    Nov 2009
    New York
    Default
    Thanks for the feedback.
    Also you guys may get a kick out of my $50 spray booth. Take a look at my build link. I used one of my old Christmas blow up motors for my exhaust fan
    John
    Mar 2011
    Default
    Ive seen some places that sell inserts for sockets that protect the bolt. probably dont hold up too much torque though. although ive also seen them for lugnuts, so they must be pretty stout.
    May 2011
    Central FL
    Default
    I tried that but the bolts wouldn't pop up when they were done...
    - David
    1967 Camaro - In remembrance of my friend Scott
    Nov 2009
    New York
    Default
    Quote Originally Posted by MyFriendScott View Post
    Now that is funny **** In the end I'm going with stainless so I can polish them.
    May 2012
    Independence, MO
    Default
    Polished stainless always looks good. If you, or anyone else, wants the painted look, try fitting all of your panels BEFORE any paint and once you have the fit you want, tighten the bolts down, drill a couple of discrete 1/8" holes in the panel (like fender to firewall, door hinge into body, etc.). Then once the panels are painted, take some 1/8" round stock cut in 4"-6" lenths with one end ground to a point and the other end bent at a 90 degree angle (for leverage). Use these to line your panels back up exaclty where they go the first time and you won't have to bolt and unbolt, bolt and unbolt. to get the panels to line up like you want. Then you can try the other tricks to tighten the bolts down (i.e. plastic lined sockets, etc.) BTW...the farther appart you drill the holes, the more exact the alignment will be, and the holes are only 1/8" so virtually not noticeable
Posting Permissions
  • You may not post replies
  • You may not edit your posts
