    Feb 2012
    Default 73 Camaro rear end
    I have found a rear end with a 4.10 posi and disk brakes from a post 81 Camaro. Suppose I cut the coil holders off and mount a carrier for the leaf springs. Will it fit? If so, reason not to do this?
    Oregon
    Default
    Post '81 meaning '82 through '92 for the third generation or '93-'02 for the fourth generation? What size ring gear, 7.5", 7.625", 8.5"? 10-bolt or Borg Warner 9-bolt? Do you have any more information and/or pictures of the rear end, ID tag, etc?
    Tobin
    KORE3
    It's what I does.
    Jun 2006
    Katy,TX
    Default
    Not sure if 73s were too early for 8.5" 10 bolt and had an 8.2 but that is still better than the 7.5" etc late model ones.
    1978 Black Trans Am 455 Edelbrock heads 10.99@124.5 through mufflers on pump gas
    1965 GTO project car
    2004 Pulse Red GTO
    Jul 2010
    Sacramento, CA
    Default
    The third and fourth gen f-body rear ends are substantially weaker than the stock 2nd gen rear end. If all you're after is disc brakes, you can bolt the late fourth gen brakes right on to the 2nd gen axle.
    -James
    1974 Z28 SCCA C Prepared
    1990 Firebird NASA CMC
    1989 Civic Si SCCA STC
    Jun 2010
    Deployed
    Default
    Quote Originally Posted by SLO_Z28 View Post
    1979-81 Trans Am rear disc is an easy swap.
    1970 Camaro/DSE build
    http://www.pro-touring.com/threads/1...71#post1147371
    Pittsburgh, PA
    Default
    Quote Originally Posted by Skip Fix View Post
    My 73 has the corporate 8.5" 10 bolt...
    Here is a cut a paste from an article discussing where to find the corporate 10 bolt:
    You can find a 10-bolt 8.5-inch differential in any of these cars or trucks:
    1971-'76 Chevrolet full-size cars
    1994-'96 Impala
    1971-'81 Buick full-size cars
    1973-'77 Buick Gran Sport
    1972-'77 Pontiac GTO and Le Mans
    1970-'81 Chevy Camaro and Z28
    1970-'81 Pontiac Firebird
    1971-'77 Olds Cutlass and F-85 and Pontiac Grand Prix
    1971-'79 Chevy II, Nova, Buick Skylark and Olds Omega
    1973-'77 Chevelle, Malibu and El Camino
    1971-'77 Pontiac Ventura and Phoenix
    1971-'81 Pontiac Bonneville
    1973-'77 Monte Carlo
    1973-'77 Buick Apollo, Regal and Century
    1980-'94 Chevy -ton and -ton pickups
    1977-'94 GMC Jimmy and Chevy Blazer
    Nick DiPrenda
    Aug 2005
    Hamilton, NJ
    Country Flag: Swaziland
    Default
    2nd gen OE rears
    1970 - 8.2" 10 bolt; 12 bolt
    1971-1981 - 8.5" 10 bolts only
    1982+ up f-body rears are junk.
    Scott from NJ. Stay thirsty, my friends
    Vent Windows Forever! ... My junk, featuring the Red Dragon ... NastyZ28 ... NJ Camaros & Firebirds
Posting Permissions
  • You may not post replies
  • You may not edit your posts
