    May 2006
    Default 548 bbc street engine complete carb to pan (never run)
Size:  128.7 KBName:  548 Pic3.jpg
Size:  239.8 KBFor sale is a brand new / never run 548 Big Block Chevy complete street engine from Carb to Pan. Short block kit purchased from Bill Mitchell Racing. Everything brand new and all quality built components. Excellent street engine with 10.38:1 compression designed to run on 93 octane pump gas. Motor complete from carb to pan and includes distributor, plugs, wires!! Put in car and run.
    Over $11,000.00 invested in this build and estimated at 600-650HP.
    Motor Details are as follows
    Short Block
    Block - GM Gen VI 502 Production Block (Block Bore 4.53, Deck Height 9.8)
    Crank SCAT 4130 Steel Crankshaft, Heat Treated, Nitrated, Hardened Journals (Stroke 4.25)
    Connecting Rods Eagle 3-D L-19 H-Beam Heat Treated (Rod Length 6.535)
    Pistons Ross Racing Pistons 10cc dome (Compression 10.38:1)
    Clevite H-Series Bearings
    C&A Zero Gap Rings
    Taper Wall Tool Steel Pins
    Bill Mitchell Hardcore Racing(World Products) Short Block Kit (all engine block machine work done by Bill Mitchell)
    Heads/Intake
    Aluminum Brodix BB2-Plus, Intake 312cc, Chamber Volume 119cc, Valve Size 2.25/1.88
    Brodix Aluminum Single Plane Square Bore Intake Manifold (HV-2001), Jet-Hot coated Sterling Silver
    Brodix BRO-9992000-3 Kit used (heads, intake, valve covers, gaskets, head studs, etc)
    Carburetor
    Competition Fuel Systems (CFS) Street Carb, (Tucson, AZ) 850 Holley #4781, 1050 CFM, S/N 3723
    Cam/Lifters/Timing
    Comp Cams Custom Roller Cam, 110 lobe separation, Lobe Lift .400, Grind# Gen6 4211S/4050R110
    Comp Cams Pro Magnum Stud Mount Full Roller Rockers, Steel, 1.7 ratio, 7/16 stud
    Comp Cams Endure-X Mechanical Roller Lifters
    Comp Cams Timing Chain & Gear Set, Hi-Tech, Single Roller, Billet Steel sprockets
    Additional Parts
    Distributor MSD Pro-Billet Street Distributor (MSD-8361)
    Oil Pan Milodon Drag Race Oil Pan, Gold Iridite, 8 quart capacity (MIL-31180)
    Starter Summit Racing Mini-Pro-Torque Starter (SUM-820323-M)
    Moroso Spark Plug wires
    Balancer ATI Steel External Balancer, 7 (ATI-917740)
    All ARP studs/hardware used
    Engine comes with engine stand (currently sitting on it) and intake lifting plate
    Sold the car this motor was going to go in and too much motor for my other car. Time to part ways with it.
    Quality built motor that is perfect for street use.
    Please call or email with questions or if you need any more specifics.
    $7,500 (over $11,ooo invested)
    NO TRADES
    Engine is located in Webster, NY
    585-953-1009
    1968 Camaro (1st car - 24 years)
    1940 Steel Willys Coupe (current project)
    1957 E-Bird Thunderbird
    1955 Chevy Sedan Delivery
    Jul 2009
    New Jersey
    Default
    Please don't take any less for this I will jump in the truck right now and my wife will hurt me
    RJ Cilurso
    67 Camaro with a few things bolted to it
    12 Camaro with a few things bolted to it
    50 Chevy 5 window p/u with a few things unbolted
    USAF
    May 2006
    Default
    She will be ok...you got clearance. Hop in the truck!
    May 2006
    Default
    Price reduced to $7,250.00
    May 2006
    Default
    Sold!!!!!!!!!!!!!!!!!!!!!!!
    Default
    What a steal!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
