Results 1 to 15 of 15
02-22-2012 #1
T56 Magnum leaking from shifter - HELP
I bought the T56 Magnum conversion from American Powertrain. That was not the smoothest install I ever did to say the least, I won't go into details.
Anyways, I finally got it down on the tires and took it out for a spin to find out that I had a good red fluid leak. I drove it home right away and found out where it was coming from - the top. I pulled off the shifter dust boot and found a pool of fluid in there, you can tell this was the source of the leak.
What is this all about? I can't see this being normal and what does it take to get this to stop leaking. I added the proper amount of ATF for the break-in. Would there be something related to the vent hose? Last time I checked, it was not pinched.
Any advice would be greatly appreciated.
Mark
