    Results 1 to 20 of 29
      Dec 2011
      Midwest
      1968 ls2 procharged Camaro
      Hello everyone, Well i figured it was time that i post some pics of my build. Lets start by talking about the car. Its a 68 Camaro, that was purchased threw a local paper called the Thrifty Nickle when i was around thirteen. My father and I restored it threw high school. We took some short cuts just to make it look good and to be honest he thought i would have had it wrapped around a pole in no time...lol. At that point i had put a 396 in it along with that it had a 12 bolt rear end and a four speed. Well, here it was a little over ten years later, having a better paying job... I decided to do it right and how i wanted it.
      Now here's what im running:
      engine:
      Forged ls2, wiseco pistons, callies rods, ported 317s, 232/240 .595/.608 115 cam, super vic intake and oh yeah d1 procharged and intercooled.
      trans:
      T-56 with hurst shifter for a retro look. mcleod clutch in time lol
      rear end:
      Track 9, 9 inch ford rear
      Brakes:
      Ls1 conversion, front and rear.
      Body:
      Some Shaved parts and custom vallance. DSe mini tub kit
      Suspension:
      Front, Hotchkis: 3 inch drop spring, sway bar and tie rod sleeves. 92 iroc performance gear box swap
      Rear, DSE 3 inch drop leaf springs for now lol
      Here is a pic of it before i started its tear down:
      Ramona, Ca. San Diego area
      Thats a great start. I'm doing a build very similar yours. Its a good that your camaro isn't an rs. The inter cooler is a pain to install on them.
      Look like you done some body mods to you car already with the smoothed marker lights.
      Whats the cubic inches on your ls2? How many lbs are you planning to run? looking forward to watching and welcome to PT.com
      67 Camaro convertible (Jinx)
      Oct 2010
      Longwood, FL
      now that is a dreamy motor!
      project 72 chevelle rs1
      Used to be known as streetmetal
      Sep 2011
      md
      that things badass
      Sep 2011
      Dana Point, California 92629
      Nice looking set-up, should rock and roll!
      Dec 2011
      Midwest
      Quote Originally Posted by 67 ls1 vert View Post
      LOL... funny you say that its good mine isnt an rs bc im converting it to one... Yeah it looks like the easiest way is good looking hood pins or a custom made rs hood latch... And yes i took out the side marker lights way back when... it look way cleaner. I plan on welding the lower fenders to the fenders also... I was going to build a 402 stroker but i was told it would over work the d1 to fill the space and i would make more power with the stock cubes. I have 4.005 pistons so i could clean it up but keep the sleeve walls thick as possible. Im running a 3.4 so people say i will be running 15-18 psi depending. Hoping for 750+ rwhp.
      Dec 2011
      Midwest
      I also made a smooth firewall plate from cold rolled 16 gauge steel... shouldn't warp lol. I purchased the big red race valve .... And i have a lemans quick release gas cap in the future.
      Dec 2011
      Midwest
      Here's a couple more pics of the sub frame. We mig'd and tig'd welded all the seams and filled everything. Also, I did a little rendering of the rear of the camaro on paint lol. And i threw another of the engine just because haha
      Oct 2010
      Longwood, FL
      very cool look for the rear! split bumper is money!
      Cartersville, GA
      Nice! I'll be doing an LS1/T56/Procharger on a '69 Firebird convertible soon.
      Joe Hinds
      You might want to rethink the RS install. I have an RS and a big inter-cooler and it is very difficult to route the tubing. You cant go beside the headlight because the head light doors open up right where you need them and if you go under the core support your piping will hang low. I'm not going to show mine yet as its still in the works. But lets say it would be way easier to have a non RS front end. I see that you bought the billet grill but you could always run the billet standard grill as an option. I am going to follow this build to see how you tackle it. Good luck which ever you decide to do.
      Dec 2011
      Midwest
      This is very true. What do you think about running the tubes threw the fender wells between the core support and the wheel. Next to the frame. It would require a rear mounted battery
      not sure how you mean? If you go in to the fenders around the core support you will be out side the headlights. Not to mention, if you go inside your inner fenders you will be over the tire and the tire will rub the piping. I know I looked in to it. Keep looking, its like a puzzle. You'll figure out something cool. Remember, you want the least amount of turns. Turns rob performance. :(
      Dec 2011
      Midwest
      Mocking up everything! custom valance, rs grill... still need to attach head light brackets.
      Dec 2009
      Engine bay is looking good Bro!
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Vacaville CA
      I didn't think that intake would clear a stock hood. Looking good!!
      Dec 2011
      Midwest
      Quote Originally Posted by Black93GT View Post
      It should clear the 2.5 cowl lol
      Feb 2012
      SW, Michigan
      Sweet looking project, love to go for a ride when finished!
      Dec 2011
      Midwest
      Yeah i cant wait either, still have to work out the kinks... This thing sits low. I need a holley oil pan. and i still have to mini tub it ... and repaint the enitre car black I also have to buy new wheels since these wont clear the calipers...
      Quote Originally Posted by Auto Rod Technologies View Post
      Nov 2009
      New York
