Results 1 to 20 of 31
Thread: Shock Relocation Kit
11-08-2011 #1Starting The Transformation
- Oct 2011
- Phoenix AZ
- 129
This Kit will relocate the shocks inboard in a stock 68-69 Camaro frame. In the 67 you will have modifiy your pocket surface, due to the pan differences between the years. (and yes there is a difference) It will facilitate larger tires with or without a mini tub. This Kit is perfect for relocating your shocks inboard.
The bracket is mild steel, tig welded, which strengthens the area between the frame rails as well. You do not need to cut into your trunks compared to other kits. Keeps the top of the shock completely hidden in the stock factory pocket. We call it "The Bump in the Trunk."
In addition, the upper shock mounting points are close to stock height, witch will allow you to lower the rear and still have the ability to choose various shocks. The kit also has two different cups, 85 and 80 degrees depending on your set up. Ive linked a back yard install video…a little rough..but…lol
Thanks Bob
