    Results 1 to 3 of 3
      Sep 2011
      Mundelein, IL
      Roadster Shop FAST TRACK 1967-69 Camaro IRS Chassis
      Introducing the Roadster Shop Fast Track IFS/IRS Camaro chassis. The only full frame, full independent, full performance chassis system on the market for the first Gen Camaro.
      Standard Features
      • RS Fast Track Front Suspension
      • C6 Corvette spindle and Z06 hub assembly
      • Adjustable Afco billet coilovers
      • 1.25" splined front sway bar with C6 Corvette end links
      • Custom fabricated, fully boxed, 10 gage frame rails
      • Utilizes all stock body mounting locations, bumper and core support mounts
      • Lowered ride height
      • Engine mounts for SBC, BBC, or optional LS Motors
      • Custom center cross member with adjustable, drop out trans mount
      • Mid brace cross member with exhaust ports for up to 3" exhaust
      • RS Fast Track Independent Rear Suspension
      • Ford 9” based center with C6 Corvette spindle
      • Fabricated 1.25” upper and 1.625” lower tubular control arms
      • Custom 300M drive axles with machined chromoly 930 CV joints rated at 1,000 HP
      • Custom machined 300M, high HP inner and outer stub axles
      • 1.25” splined rear sway bar
      Performance
      • Designed to accommodate a 10” wide front wheel with up to a 295 series tire, and a 12” wide rear wheel with a 345 series tire
      • Controlled roll center, matched front to rear, for predictable performance
      • Matched front and rear suspension camber curves.
      • Built in caster and camber street settings, easily adjustable for track set ups
      • Optimal motion ratio for accurate spring ratings yielding comfortable ride and exceptional performance
      • Delrin control arm bushings to reduce deflection and maintain suspension settings and ride quality.
      • Light weight components for lowest unsprung weight without sacrificing strength
      • C6 Corvette spindles, hubs and lower ball joints
      • Performance Improvements over Stock Corvette Geometry
      o Increased Negative Camber Gains
      o Increased Wheel Clearance (to Control Arms)
      o Increased Strength
      o Drastically Reduced Bushing Deflection
      Pricing and additional information can be found on our website at:
      http://www.roadstershop.com/products...camaro-chassis
      This is absolutely killer! Can't wait to see it in action
      Tallahassee + Seminole, Florida
      Looks like a bad piece. Been needing something like this.
      Max
