    Page 1 of 25 1 2 3 4 5 6 11 ... LastLast
    Results 1 to 20 of 486
      Mission Viejo, CA
      1973 Pontiac Grand Am LS7 Swap
      Name:  Picture 029 (Large).jpg
Size:  144.6 KBName:  2011-10-03 13.56.17 (2).jpg
      This is a new thread I am starting to document my LS7 swap into my PT 1973 Pontiac Grand Am.
      Part of the build includes re-doing the entire frame. When I originally restored the car, I had done a body off. Frame powder coated and all the rest that goes with it. Unfortunately after that I was always chasing a mild lean towards the driver side. Had a local frame shop check it, and found it to be lower on that side?? Hard to figure why considering the I am the second owner since 1989 and the original owner was 80 years old when he sold it to me. The car never had the lean before I restored it. As luck would have it, I located a 1973 LeMans at a local specialty wrecking yard a few months ago. I decided the best way to approach this was to get the other frame and swap everything over. Last week I pulled it all apart. It took 3.5 hours and none of the bolts stripped or were rusted solid. I know.....we California guys are spoiled. Dont hate me. I decided to take the frame to Rob MacGregor at No Limit Engineering in San Bernardino, Ca. The plan is to have Rob re-weld all the factory welds, box the entire frame, add cross bracing in critical areas, and true the frame. I will powder coat the frame medium/dark gunmetal grey metallic when it's finished. Rob told me they took preliminary measurement of the frame and it was only 1/8” out which he said was very good compared to others he has worked on. He pointed out all of the areas of the frame that need to be improved. He said all of the factory welds on this particular frame were better than most, but will all be re-welded. It would be nice to step up to the plate and buy a custom frame, but I just dont have that kind of money, so this is the best alternative. I did tell him I want to go to a rear coil over set up. I will be bringing him the rear diff next week in order for him to mount it to the frame to get everything squared up for the coil set up. Since I already have a complete Global West front and rear suspension on the car, I will be swapping those parts back to the new frame. ERL called me today. The short block is being machined now, and will be finished by the end of next week. As soon as I know what the piston to deck height is, I am ordering the heads in order to get the compression ratio between 11-11.5:1. I had initially intended on ordering WCCH Brodix castings, but I have recently went to Dr. J's Performance and spoke with Bryce regarding his Air Wolf CNC ported heads. They are very impressive. I have not decided yet which ones I will get. I received the cam from Geoff at EPS and the MAST oil pan. Shaun at SMC Performance has supplied me with a lot of parts as well. The intake is a factory LS7 ported by LS2 Portworks. The cam specs are .633/.640 lift, 226/242 @.050 on a 115+3 LSA. I inserted a picture of some of the parts I have so far. I will continue to post the entire build as it progresses. Thanks.
      1973 Hurst Edition Pontiac Grand Am: 430 CI of ERL built LS7, Tremec Magnum T-56 6-speed, Global West / Speedtech Suspension, Custom rear coil-over suspension, QA1 double adjustable shocks, Wilwood 6/4 piston disc brakes, Modulare C1 19" concave wheels. Shooting for 625 HP and 20 MPG!
      I knew it! When I saw your new engine go up for sale I figured this was going to become a badazz LS project.
      Planning on duplicating this build on the PY forum? Hope you're wearing armor-plated underwear. LOL!
      This thing is going to be awesome. Good luck.
      EDIT: See you already did start it on PY, and with positive feedback too. Pontiac crowd must be warming up to these swaps finally.
      fvgbhnj
      Birmingham, AL
      This is gonna be awesome. Keep us posted on the progress.
      Stephen
      Mission Viejo, CA
      Yeah, I had to sell off all of the Pontiac engine parts in order to finance this. Thanks for the feedback. I am pretty excited about this. The PY guys can be brutal, so we will see. I will be posting all the build on PY and Pro-Touring as well. Today the rear diff comes out. Thanks.
      Sean
      Dec 2009
      Hey Sean - Badazz for sure. I'm curious how you picked your cam before you selected heads? Wouldn't flow affect your decision? The cam you have is a little beefier than the one I'm putting in my LS7, although I'm hunting torque. Are you running a 1.8 or 1.7 rocker ratio?
      Edit - Richard @ WCCH would be my choice!
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Mission Viejo, CA
      Ron,
      I know that I will be running ported LS7 heads regardless of which ones I pick, but I knew the flow numbers were going to be in the 375-390 range either way. The only reason I have not bought them is that I am still waiting for the piston to deck height clearance values so that I can set up the chamber size correctly for the CR I want. I am running the standard 1.8 LS7 rockers on this set up.
      Mission Viejo, CA
      LS7 Swap Progress
      Well I decided to work on the car today. Here is the progress. The two dolly's really help when your doing it by yourself. Now it's off to the rear end shop to have them inspect everything. After that it goes to No Limit for the coil over mock up.Attachment 49970
      Sep 2008
      this is going to be a great build! I had a 73 GTO that I build to duplicate the 73 SD 455 4spd ascot silver. it was a great car, but got bored of just showing it at car shows, sold it and am working on a pr-toured 69 Firebird with a 418 LS, after this am thinking of doing a 77 Can Am pro tour with an LS, I will be watching your build!
      Imran
      Mission Viejo, CA
      Thanks Blackgoat.
      Birmingham, AL
      Do you have any pics before the tear down?
      Stephen
      Mission Viejo, CA
      Attachment 50003Attachment 50002
      If you meant the whole car, here are two pictures.
      Feb 2010
      Central NJ
      This is going to be awesome... I'll get my pen and paper ready for notes... Good Luck with the upgrade!
      -Sean
      Dec 2007
      Lombard, IL
      Very cool.
      My sister had a really cool (and fast) triple black 73 Grand Am when I was in high school. I always like the lines of that car. Yours looks great.
      Can't wait to see your latest iteration come together.
      Dan
      1971 Chevelle Maliboo Convertible 496/4L80E
      1956 210 2 door Sedan 8-71 blown 468/T400
      Mission Viejo, CA
      Thanks Sean....nice to see another '73-'77 A-body member taking interest. I like your Bad Buzz name. I need to think of a name for this project?? I'm open to ideas.
      May 2008
      Austin, Tx.
      VERY cool project!
      That car has an awesome looking grill/front end on it!
      Ray
      Houston, TX
      DUDE!!! My favorite ride of all time! I'm gonna be watching this for sure.
      Asa Walker
      Houston, TX
      Mission Viejo, CA
      Cool guys. Thanks for the positive comments.
      Sydney, Australia
      Country Flag: Australia
      Very nice...I love the 73 A body Pontiacs...great lines.
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
      Jul 2011
      Nashville/ Tampa
      Interesting car. Honestly don't think I've ever seen one before.
      https://www.instagram.com/gen_v_lt1_chevelle/
      Do not buy anything from Frankie's Used Auto Parts. Ever.
      Chevelle ̶a̶l̶m̶o̶s̶t̶ ̶f̶i̶n̶i̶s̶h̶e̶d̶ L92/200-4r now Gen V LT1 and T56- https://ls1tech.com/forums/conversio...nvertible.html
    Tags for this Thread
