    Page 3 of 22 FirstFirst 1 2 3 4 5 6 7 8 13 ... LastLast
    Results 41 to 60 of 431
    1. #41
      Charlestown NH
      these didnt make it up for some reason
      https://www.pro-touring.com/showthre...-Touring-Truck
      DMP Fabrication LLC
      Follow me on Instagram for welding and truck progress! - Americangraffiti
    2. #42
      Albemarle, NC
      Quote Originally Posted by the dan View Post
      rims are 20" x 8.5. 5.5 on 5. thats kinda my secret where they came from.
      arent our trucks 5X5 factory though? are you using adapters for the ram 1500 wheels?
      Michael Crawford
    3. #43
      Charlestown NH
      the 9" is a big bearing out of an F150 with 5.5 on 5, and i have billet adapters for the front
      DMP Fabrication LLC
    4. #44
      Charlestown NH
      Thanks to Ron S and a bunch of other intelligent people in the Search section of Disc Brakes,
      I Ordered my Wilwood Pedal assembly and 7/8 Tandem Master Cylinder as well as clutch master. there is tons of info that i read up on about what to go with especially going from power to manual brakes, And what one guy said on a link to Lateral G, "If there is a rod hanging out the side of the car, manual brakes will still come to a stop"
      DMP Fabrication LLC
    5. #45
      Charlestown NH
      got a few boxes from wilwood
      pedals had to be moved toward the seat so i made a box to fit everything and mount the assmblies and fitted it
      then somehow after i got them in the measurement was off in the height 2 inches... so i had to cut it back out and decided id do it legit and cut all my driver firewall out
      then made a template for the new piece
      i also machined off some of the material off the air compressor mounts. i dont need it 1/2 the whole way.. i guess a little weight saving doesnt hurt
      DMP Fabrication LLC
    6. #46
      Feb 2012
      SW, Michigan
      nice frame work.. the whole project looks nice.
    7. #47
      Nov 2011
      Your truck is sick. You do really nice work and especially for your age. I'm a bit jealous.
    8. #48
      memphis
      very sick
      Dave
    9. #49
      Charlestown NH
      Quote Originally Posted by dug View Post
      This is partially why i do it. keeping a positive outlook on my ****ty generation. I grew up on old school religion, 32-34 coupes, American Graffiti, and no alcohol. Why buy a new truck when i can build the truck of my dreams?.. well almost
      DMP Fabrication LLC
    10. #50
      Charlestown NH
      Thank you
      DMP Fabrication LLC
    11. #51
      Charlestown NH
      passenger firewall is done and seam sealed around the inside... driver side is being a PITA with that pedal box, but ill make it work, gotta cut the box down about in inch, trying to get as much leg room as possible.
      DMP Fabrication LLC
    12. #52
      Coronado, CA
      I almost went with a Chevy bolt pattern on my Plymouth. I custom ordered the rear and I could have changed my Wilwood hubs around. I stayed with the factory pattern. Sometimes I wish I would have so I could have snagged a used set of premium wheels easier.
      It's good to have options though.
      Johnny C.
    13. #53
      Charlestown NH
      Quote Originally Posted by go-fish View Post
      Issue with Wilwood hubs or anything for that matter is 5.5 on 5 isn't a typical pattern, and never one for any sort of race application. Kinda sucks but in living with it. I really dont want to run adapters but there isn't enough room to drill such a large pattern
      DMP Fabrication LLC
    14. #54
      Charlestown NH
      Tonight i ordered an Ididit tilt steering column, and cut all but a half inch off the pedal box, and i dropped the driver floor down 3" so the pedals could move forward. it wasnt perfectly comfortable when i was sitting in it so i figured do it now instead of regreting it later...
      DMP Fabrication LLC
    15. #55
      Apr 2010
      Jersey Shore
      So you'll be driving this to RTTS with us right? Haha. Looks awesome as usual
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
    16. #56
      Charlestown NH
      Got the upper A arms tacked into location with extra tubing to notch, and tested how far the suspension travel is. and it will drop to the ground stuffing the 20's on corvette c5 suspension. pretty pumped about that.
      also finished the center section to my firewall had it all laser cut at work/ as well as redesign and welded in the pedal box
      then got a roll on the engine cover since the center section of the firewall will be tigwelded to the engine cover i wanted to prove everything out before i started at it
      DMP Fabrication LLC
    17. #57
      Birmingham, AL
      This is a a top 5 build on here for sure and that is saying a lot. I love the square bodies and this one is really going to be amazing.
      Stephen
    18. #58
      Charlestown NH
      can you see all 4 pictures? for some reson the links are there but i dont see the pictures
      DMP Fabrication LLC
    19. #59
      Apr 2010
      Jersey Shore
      yes
      also... I left your gauge in the box next to the shop
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
    20. #60
      Charlestown NH
      been doing alot of customer car work but that just means more income for the c10
      Tonight i tackled one of the hardest things ive had to do yet, and thats make a contoured cut in a blind area, it came out fantastic and do not think i could ever do it so nice again if i had to.
      thats the picture inside the cowl
      oh and i forgot to mention i had to pull the cab off and shorten the frame 1.5" because the truck isnt factory wheel base anymore for some reason... the front wheel was off center 3"... so the motor is back 1.5" more now so i had to remake the engine tunnel wider and also made it higher for the future fuel rails, 3" higher
      more to come of coarse.
      DMP Fabrication LLC
