    Page 21 of 22 FirstFirst ... 11 16 17 18 19 20 21 22 LastLast
    Results 401 to 420 of 431
    1. #401
      Mar 2018
      la mesa, CA
      This Build is Epic! Im going to be following it for sure.
      Follow my Instagram
      And my build on here
      check out Opentracker Racing Products
    2. #402
      Apr 2010
      Jersey Shore
      Everything looking awesome as usual!
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
    3. #403
      Aug 2011
      Connecticut
      Wow man, this is such a good build!
      1967 Firebird "Poor-Boy Build"
      New updated thread
      https://www.pro-touring.com/threads/...bird-(Updates)
      Follow me on Instagram @NaturalLivingMan
    4. #404
      Jun 2017
      Edgewater Co.
      Quote Originally Posted by the dan View Post
      And the front fender dent is the reason why brothers never get along. lifted 3+3 big block chevy fell out of gear and used my fender as a praking brake
      "You can choose your friends but you can't choose your family"...
      Just found this thread, awesome build. With the fab skills your showing, you'll go far...
      Joe
    5. #405
      Dec 2010
      Charlestown NH
      Quote Originally Posted by Motoracer838 View Post
      Joe
      Thanks Joe!
      Here are the res' mounted on the frame. Todays project is master cylinders, battery hold down and shockwave bracket improvement.
      https://www.pro-touring.com/showthre...-Touring-Truck
      DMP Fabrication LLC
      Follow me on Instagram for welding and truck progress! - Americangraffiti
    6. #406
      Jun 2014
      The resivor mount is dope. I always look at your thread and wonder what you made and what you bought. Quality is top notch as usual.
    7. #407
      Dec 2010
      Charlestown NH
      I make almost all of it because I can't buy anything I like. Lol. Much appreciated.
      No updates tonight. Tilton didn't give me an oring on one of my masters so I couldn't bench bleed them all and mount them. front brakes and suspension are back together and I need to get some material for my battery tray tomorrow
      DMP Fabrication LLC
    8. #408
      Dec 2010
      Charlestown NH
      I got my new Tilton masters in place, One of them came missing an o-ring for the res, so MCMASTER has an EPDM ring coming today
      And checking clearance on 325's for the front
      DMP Fabrication LLC
    9. #409
      Apr 2011
      Very Nice!
      Have a few questions for u. Did u run braided lines all the way to your brakes or do u have hard lines? Tell us more about the front suspension and the Fox shocks please.
    10. #410
      Dec 2010
      Charlestown NH
      ps ive tried 3 different times to upload that image properly. Every time google decides to rotate it, even after i download, rotate, save, and re-upload it
      DMP Fabrication LLC
    11. #411
      Dec 2010
      Charlestown NH
      Quote Originally Posted by hotrod56 View Post
      Very Nice!
      No, Soft from the res to 3/16 stainless hard line, then hardline to the axle, and to the front crossmember where i then used steel braided up front for movement, and the rear has regular c5 vette lines. The rear isn't an issue for the brakes, the front is my main concern.
      Front suspension/cradle is 04' C5 Corvette, brackets are custom to hold the shockwaves. Engine mounts to factory C5 motor mounts and puts the engine back about 10/12" from stock
      I had 2 sets of QA1's that blew out in less than a year each. I work for an OEM and decided that if FOX can run their 2.0's in an OEM, then those are what i want. I need alot of travel to get the rear end out of the wheel well, i tuck about 5" at ride height which requires about a 8" stroke shock.
      DMP Fabrication LLC
    12. #412
      Dec 2010
      Charlestown NH
      One of the best investments in the shop was my cnc plasma table, even after 6 months, i'm still learning the programming and parameters but btw that and solidworks it makes brackets really easy.
      I had made custom nuts to hold my optima down by the base, since i ditched that, i had to retrofit my strap onto my existing mount. I kinda wanted to remake the whole thing, but i kinda would rather drive it this summer.
      Hood Hinges from Little Shop Manufacturing. Couldn't make them for what you can buy them for, so far they are a really nice piece. AND you get a T shirt with it!
      DMP Fabrication LLC
    13. #413
      Dec 2010
      Charlestown NH
      Back on all 4's with some new (used) tires up front. Bed is going on tonight. Its been 100 all weekend and going to be high 90s all week with 50% humidity. Its hot
      Got my engine back from BTK
      Hopefully I get my LS timing, valley, and valve covers back and have the thing running this weekend. Still have to redo the radiator and replumb some stuff
      DMP Fabrication LLC
    14. #414
      Jun 2012
      N. Shore, Ma
      Hows the progress?
      Eric
      Building 1969 GTO - Roadster Shop chassis, LQ9 w LS3 heads and rebuild parts from TSP, Bowler prepped Magnum T56 6 spd, 3 Link Strange 9" w Speedway Floater Hubs, Wilwood 14" F - 13" R brakes, 275.18 - 345.19
      https://www.pro-touring.com/threads/94970-69-GTO-Build
    15. #415
      Dec 2010
      Charlestown NH
      Been too busy to update, probably wont have another for a while. Got it together and to the dyno on Saturday. 645/571 rear wheel on 9psi. Having an engine built by someone who knows camshaft profiles was one of the best things i ever did. The torque curve is 375ft/lb at 2500rpm. The cam and displacement use the blower alot more. The same pulley setup ran 12.8 psi on the stock 6.0. I will work on the tune some more and get it more crisp when I have more time for another session.
      Also: I will probably never run air ride again. I had a line blow out on the dyno from exhaust heat and barely got it back on the trailer. the line was on the opposite side of the frame as the exhaust.. Make sure you have ample air flow when having your vehicle load-tuned (he can hold back 650hp with at any RPM) and use thread sealer, NOT teflon tape, on your steam ports.
      Also buy Injector Dynamics injectors for anything youre building.
      Getting new tires from Chris at Autoworks NJ this Friday as I drop the billet capped fuel cell for his 69' vette. and hopefully get my Ebrake setup
      DMP Fabrication LLC
    16. #416
      Jun 2012
      N. Shore, Ma
      Nice job getting everything together!
      What compression pistons are you running?
      Those are great dyno numbers for a conservative 9 psi.
      Eric
    17. #417
      Dec 2010
      Charlestown NH
      Quote Originally Posted by ekmxryda View Post
      -15cc pistons give it around 9.2:1
      DMP Fabrication LLC
    18. #418
      Jan 2019
      Krasnodar
      Country Flag: Russian Federation
      I really like your project, it inspires me
    19. #419
      Dec 2010
      Charlestown NH
      So i ditched the KRC pump as it sucked, the service department wanted no help in figuring out a solution after i blew 2 caps off of it during an event and almost lit the truck on fire. so here we are. Made a idler to keep m belt route
      DMP Fabrication LLC
    20. #420
      Dec 2010
      Charlestown NH
      MR2 Electric Power Steering pump with a custom baffled tank and the stock cap
      So Here it sits on 325 x 19's on all 4. I have to massage the fenders to fit the wheels
      DMP Fabrication LLC
