    Results 1 to 7 of 7
      IN/MI border
      pinion yoke, 1310 or 1330??
      Currently have a 12 bolts with a 1310 pinion yoke. Motor should be around 500hp at the crank. Do I need to upgrade to a 1330?
      Auburn, CA
      Auto or stick? Auto, not really.
      Stick, if you like to side step the clutch yes. If you take it easy no. I have a 496 living in front of a stock t56 and 1310 12 bolt. It will take a lot of abuse. With that said, when I go through there again I will upgrade just in case.
      Tim Tracy
      Mar 2004
      Mid-Michigan
      Like Tim said. Unless you are really beating on the car AND hooking all of that power, you shouldn't have a problem. I am going 1350's on my Bad Ast build just because it is all brand new anyway but, in your case, not really necessary.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      san diego
      I would say no as well. Maybe if your car was really heavy and you were launching on slicks.
      Jan 2009
      San Antonio, Texas
      Since I'm in the same boat as the OP, I hope he doesn't mind if I do a highjack instead of starting a new thread...
      I have a 3,300# Javelin, 500 at the crank, T-10, Speedway Engineering full floater 9". Some street use, but mainly track car (NASA American Iron). Ordering a center section and figure 1330 should be strong enough. Guess the only drawback would be the extra weight of the 1330, but can't imagine that extra weight would be a reason to use a 1310 that might not live.
      Your thoughts?
      Scott
      Check out my YouTube channel for vintage car and truck rescues and rebuilds! THE BULLETPROOF GARAGE!!! - YouTube
      san diego
      Nascar uses a 1310, the reason is weight. Rotational mass is equivalent to about 6 times a static mass. I run a 1310 in my drag mustang. 2800lbs and 10.5" slick, launching at 5500rpm with a clutch; no issues at all and that is with the front wheels off the ground.
      Jan 2009
      San Antonio, Texas
      Spoke with one of the techs at Randy's Ring and Pinion. He recommended a 1350 u joint. Said that if I wanted to use a 1310 u joint and a Daytona pinion support that I would have to use a cast yoke. If I went with the 1350, I can use a billet or forged yoke.
      Scott
