    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 44
      Aug 2011
      1971 Chevelle SS Clone LS3 swap
      I had this thread kind of running in the welcome section and decided to move here. So if you want to see some pics of the car you can check out the welcome section.
      I pulled the motor today, installed the '04 Z06 seats and some Morris retractable shoulder harness seat belts too. I have a GMPP crate LS3 coming Tuesday or Wednesday, a TSP cam (225/230), Stainless Works 1-7/8" headers and Stainless Works 3" exhaust. I ordered a built 4L65E from Prodigy Customs and also ordered Ricks vaporworx tank from Prodigy as well which will probably take a while longer. Here some pics of my progress so far.
Size:  124.1 KBName:  IMG_20110821_163100.jpg
      Aug 2011
      I forgot to mention I pulled the console out too to fix some holes someone drilled into it years ago and will freshen the paint up on it too. I also got a Shiftworks shifter conversion to match the 4L65E pattern with a cool OD indicator :-) I am so excited to finally be doing this project.
      May 2011
      socal
      sounds like a fun combo ur putting together and those seats look amazing kind looks stock.do u have any pitures of the ride
      hpjunky danny
      1969 camaro project wayne due c4 subframe
      2004 scsb silverado jgpclone forged 370 lq9 tt gt3071 built 4l60e trans 4:10 gears daly driver
      Aug 2011
      Here are some pics of the car:
      May 2011
      socal
      like the color
      hpjunky danny
      Aug 2011
      I am kind of surprised how at home the Z06 seats look in the car. The vertical pattern on the door panels blends well the the vertical stitching on the Z06 seats. The power seats were an easy two wire hookup too. However, I had to connect 12v(+) to both orange wires in the seats connector to get it to function. And I hooked ground to the black wire with white stripe.
      May 2011
      socal
      dont u just love it when it goes smoothly
      hpjunky danny
      May 2011
      Scottsdale, AZ
      Cool SS project, big plans for other mods?
      Courage is being scared to death... and saddling up anyway.
      -John Wayne-
      Aug 2011
      Quote Originally Posted by Hondo78 View Post
      Yeah I am planning big brakes, suspension and probably Fikse profil 5 18" wheels. Either Baer 13" track 4 or Wilwoods. Just focusing on driveline first. _
      Aug 2011
      Quote Originally Posted by jgpclone View Post
      I always expect things to go terribly wrong so when things go smoothly its very surprising.
      Aug 2010
      Tacoma, WA
      Glad to see another A Body project. Can't wait to see how it pans out.
      Feb 2011
      Kalamazoo, MI
      Badass man! Loving the seats!
      1969 Pontiac GTO
      -The Nameless project.
      0331, USMC, Semper Fi.
      Jul 2009
      Cypress, TX
      Very nice. I've always been partial to blue.
      I'm doing a very similar seat installation on my 69 Camaro. Did you modify the tracks at the front? I was thinking about taking off the bracket at the front, as it raises the front of the seat about an inch or so, and I have limited headroom in the Camaro.
      1969 Camaro - LSA motor, 6L90 transmission, TCI front subframe, TCI torque arm rear suspension, Ford 9" rearend
      iceland
      Country Flag: Iceland
      Awesome project..... I'm in the same position as you swap Ls3 for 307 in to 71 Chevelle
      Aug 2011
      The C5 Vette seat tracks sit flat on the floor in the back of the seat so your about as low as the seat gets. You might gain a 1/2" by chopping the front down but the
      under thigh bolster wouldn't even touch your leg and it wouldn't lower the back of the seat where is butt is much anyway. I didn't modify the seats at all and I am about
      2" lower than before. I had to make new holes for the back of the seats since the track is longer. It is a great mod and the C5 seats being so thin up top look a lot like
      the original seats shape wise. Oh, the driver seat is power and there is a trick you can do to gain another 3/4" head room by trimming down stop. I used to have a C5
      and I did that to get more headroom. But don't need to on the Chevelle.
      Aug 2011
      I am so excited to be working on the car. Haven't been this excited since I was a kid. I picked up the crate motor today WoooHooo.
      Aug 2011
      Got the LS3 today
      The freight company called today that my LS3 was at the freight dock. I went and fetched it. Note the TSP 225/230 cam sitting next to it Name:  IMG_20110823_210356.jpg
      Jul 2009
      Cypress, TX
      Thanks, I appreciate the info.
      Aug 2011
      I got the Shiftworks horseshoe shifter kit today and installed the PRND321 bezel into the console. I also filled holes someone drilled into the sides of the console, repaired some screw holes and repainted it.
      Aug 2011
      I got the Shiftworks horseshoe shifter kit today and installed the PRND321 bezel into the console. I also filled holes someone drilled into the sides of the console , repaired some screw holes and repainted it. Now the shift pattern and detent will match the 4L65E's shift pattern. This weekend I will remove the old TH400, driveshaft, fuel tank the remainder of the exhaust system. While I am waiting on the new transmission I will finish working on the shifter mods and straighten the driver and passenger window glass and fix a rattle in the passenger door. Also want to get the TSP cam and spring kit in the motor while its out of the car.
