Results 21 to 40 of 115
08-19-2011 #21
Not much done since last post, going to pick the rear barke kit soon and install and either learn how to bend brake lines or send the chassis to a local hot rod shop. I saw project 66 Chevelle LQ9/T-56 Project LS heap, and I thought I would bring my thread back up so he can see some of the work that was done to my floors and trunk-may be of some help.
64 F-85 post car Resto-Mod project-my RV when I retire
09-14-2011 #22update on F-85 Rustbucket
A lot of little detail going on with the chassis since the last post. Here are pics of the body at the restoration center and some of my trial and error handy work. I took the 425 block and 200R4 and set it in the mounts in order to determine how far back I need to move the cross member for drive shaft length and parking brake cables locations. Shot of the big IROC-Z 1LE 12 inch discs on the B-tall spindle upgrade , Russell braided soft lines and some mock up work; learning how to bend and double flair brake lines. That is an art all by its' self! Decided on Moser finned drum brake set up for the rear. Restoration Center may start putting the top coat on by Mid-October. FYI- I gave them a year plus time frame on the extreme amount of work the "rust-bucket" needed plus as a fill in car between jobs that were on a timely basis I can't tell you what I saved on this project. Phil is just a great guy end of sentence. If you are not in a hurry with high quality job for the $$$ in the DFW area you may want to contact him. As you are aware in the DFW area it's been over 100 degrees for over 70 days no significant rain reported since June 13th. were on fire in a lot of areas;other than that were okay let's build and share our camaraderie Robski...
09-15-2011 #23
