    Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
    Results 21 to 40 of 90
    1. #21
      Boonville, Missouri
      You are the first to inquire about a Nova! Aren't the nova's in the bumper like the Chevelles. I'll look into it.
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
    2. #22
      Oct 2012
      Bay Area, CA.
      just sent you a PM, wanting to purchase...
    3. #23
      Jul 2012
      NOLA
      Tony,
      PM sent.
      - Sammy
      69LSX
    4. #24
      Jan 2013
      washington
      They look great! How affective are they on the road?? does anyone have clear smooth lenses to replace the originals?
    5. #25
      Boonville, Missouri
      At the moment there isn't a clear smooth lens being produced. I've had a bunch of e-mail regarding this however. The tooling isn't the problem with the plastic - it's the up front amount you have to purchase that is the hard pill to swallow.
      Tony Edler
      Illumin8s
    6. #26
      Aug 2012
      Wilton ,CA
      can i hook this up on my 68 firebird?
    7. #27
      Sep 2012
      I have these in my 69 z28. Other than wiring being reversed and the brackets not fitting tight in the housing. They are pretty Damn sweet. Everyone who sees them asks where I got them
    8. #28
      Boonville, Missouri
      Anthony - Please explain the brackets? Are you referring to the stainless steel parts that fit in the lenses? If you are, please contact me as I have learned that there are basically two lenses on the market now. One is a correct repo that matches that factory OE specs and the other that has no number and is molded using more uniform wall thicknesses (today's standards for prevent material sink spots). I have tabs for both and will gladly send you some at no charge.
      Tony Edler
      Illumin8s
    9. #29
      Boonville, Missouri
      As far as the '68 birds go. I've had a few in my hands and I'm totally frustrated with how GM manufactured there housings. There are alternatives to my product on the market that utilize SMD (Surface Mount) LED's that are from China. The concept is great - however the depth of the socket to the circuit board prevents them from properly engaging the socket. They need about 1/16 more depth and these would be great. The GM housing have a crimped/rolled edge that on the inside of the housing. Using a standard bulb - it's perfect. If you are willing to chamfer or grind down the ridge - I think you could be in business. Please note that these are not as bright as my all forward facing LED's but they will function the same. Please contact me if you would like additional information. Thanks -
      Tony Edler
      Illumin8s
    10. #30
      Jul 2009
      ma.
      I wish I had seen these a year ago when I made my own, I could not figure out the parking light and signal so I installed separate lights behind the grill.
      having driving lights make all the difference in the world even with hid headlights.
    11. #31
      Boonville, Missouri
      Nice looking car!
      Tony Edler
      Illumin8s
    12. #32
      Boonville, Missouri
      Here is look at stock versus Illumin8s.
      Stock - Amber Bulbs
      Illumin8s
      Next up are the video's coming shortly!
      Tony Edler
      Illumin8s
    13. #33
      Boonville, Missouri
      Daytime Running Lights - 69 Camaro
      Video!
      http://youtu.be/5wCB80_SyqE
      This video shows the directional indication without the parking lights on. Just like stock.
      Tony Edler
      Illumin8s
    14. #34
      Boonville, Missouri
      http://youtu.be/dP6F_H61a6s
      Here is a video showing the parking lights being illuminated and changing colors to show directional indication.
      Tony Edler
      Illumin8s
    15. #35
      Jan 2007
      Yardley, PA
      They are pretty darn cool.
      I hit the website, and it doesn't seem to work right at home. The links and the instruction links are dead.
    16. #36
      Quote Originally Posted by Bigblue73 View Post
      Pretty slick. Looks like you're trying to employ a "switchback" circuit. Are you able to rig it so the DRL switches off completely while the turn signal is operating? That seems to be the direction the OEM's are going in with their set ups.
      1971 Camaro
    17. #37
      Boonville, Missouri
      This is using the cars stock wiring and taking advantage of the 1157 connection. I've designed this for the folks that don't want to cut into or re-wire the front harness of there vehicle. This is a true plug and play application.
      Turning them off while blinking can be done by implementing a few new components and cutting into the harness.
      Tony Edler
      Illumin8s
    18. #38
      Maybe offer both versions. A true switchback operation looks really cool (I have it on my Camaro and have been approached by several folks with late model cars and DRL's wanting know how someone with a such an old car managed to incorporate such a cool late model feature).
      1971 Camaro
    19. #39
      Boonville, Missouri
      Here's a quick update - I'm starting the 67-68 RS Camaro's tonight. Look for photo's soon. Keep the requests coming!
      Tony Edler
      Illumin8s
    20. #40
      Jan 2007
      Yardley, PA
      I would like to get some rectangle ones, and mod them into my 79 Olds cutlass wagon parking lights. Do you make rectangle ones for another vehicle? what are the dimensions?
