Results 1 to 10 of 10
    Default 1968 Camaro Wheel and Tire Size
    I have a 68 Camaro trying to figure out whats the largest Tire, Wheel combo I can run? 2" drop in front, stock 12 bolt rear. I want the pro touring look with out tubing?? Any help would be great.
    Oct 2005
    Corona, CA
    Default
    When you say largest are you asking about width, diameter, or both? Most of our customers end up going with 18" wheels. If that is the case, 18x8/18x9's with 245/40/18 and 275/40/18 is the sweet spot. If you have any questions feel free to give us a call at the shop.
    Default
    I was refering to width and diameter. Thanks a ton. I thought that would be the size but wasn't sure.
    Pensacola, FL
    Default
    These are 19x10 with 275/35 tire on my stock 67. They were on a 69 before i got them, and they barely fit on the 67. Can get back spacing off them if you need. I have an 8.5 10 bolt but the width should be the same on stock 10/12 bolt. Scott
    Default
    NICE RIDE!!! If you could find the BS that would be great. Does the rears rube?
    Default
    We typically do 18x8s and 9s with 245s and 275s for a safe fit on a low car. 19s look so good on them but unfortunately 9.0 isn't a standard width in 19.
    Jason
    Jan 2009
    Hermosa Beach, CA
    Default
    Im running 18x8 front, 18x9 rear Boyd Coddington Junk Yard Dog 2-piece aluminum wheels, powder-coated in flat black. Toyo Proxes 225/40-18 front and 275/35-18 rear. But the rears are a bit too small diameter, Im going to go with 295/35 for next set, that will be a half inch larger diameter. My car is lowered 3" in rear and 1.5 in front.
    Check out this site for measuring changes: http://www.miata.net/garage/tirecalc.html
    Pete
    1968 Camaro
    2009 Porsche 911 Carrera S
    http://www.cardomain.com/ride/2543199
    Oct 2011
    Default Offset of 8J wheel for C5 brakes
    Quote Originally Posted by Pete68 View Post
    PLEASE Pete can you give my the offset of your 8J wheel? (9 inch wide wheel lip to lip)
    I am going to install the same C5 brakes and will get it same way. Will go with 17".
    Jan 2009
    Hermosa Beach, CA
    Default
    Quote Originally Posted by Marc View Post
    I think it was:
    Front: 18x8. Offset: +12, Backside Setting: 4 1/2 (Tires: 225/40-18)
    Rear: 18x9. Offset: 0, Backside Setting: 5 (Tires: 275/35-18)
    But check with the guys at Boyd's, they can help. http://billetwheel.com Talk to Chris
    Pete
    1968 Camaro
    Dec 2007
    Atlanta, GA
    Default
    Quote Originally Posted by JayR View Post
    Jason: Is that 245-45-18 front and 275-40-18 rear?
    Mark Z.
    1970 Firebird Formula 400
    2012 Ford Mustang Boss 302 - It really is a street legal race car.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
