    Warminster, PA
    Default 70 T/A Front End On 79 T/A
    I saw on the firebird gallery a guy put a 70-73 T/A front end on his 78 T/A doesnt look bad... Makes me think of doing this to my 79... what do you guys think bout this? Also how hard would it be to do? Would i use my 79 fenders and just plop on the 70-73 nose or would i need the 70-73 fenders too?
    Here Are Pics:
    http://www.firebirdgallery.com/2nd%2...s/78ta21.3.jpg
    http://www.firebirdgallery.com/2nd%2...s/78ta21.1.jpg
    http://www.firebirdgallery.com/2nd%2...s/78ta21.2.jpg
    http://www.firebirdgallery.com/2nd%2...s/78ta21.4.jpg
    http://www.firebirdgallery.com/2nd%2...s/78ta21.5.jpg
    1979 Trans Am - In the big junkyard in the sky
    1980 Turbo Trans Am - In the big junkyard in the sky
    A journey of a thousand miles begins with a single BURNOUT!
    IL/TN
    Default
    you realy need all the front sheet metal including the core support but I've heard of people using the 70-71 nose without doing too much work (70-71 is much lighter and does not need as many bracket but you will need the bumper brackets to hold the nose and you will have to re drill some of the mounting holes on the fender, this is about all the help I can give, it's been a long time since I played with the early firebirds
    pro-touring-body.com "doing what they say can't be done"
    Warminster, PA
    Default
    thnx for the info man, it is probably more of just an idea, and not something ill actually end up doing... but if i do id probably use the 68 or 69 style.
    IL/TN
    Default
    68 or 69 now you are looking at some big custom job and the body line would not fit right. even the 68 to 69 don't interchange!
    dallas tx
    Default
    68-69 would look rediculous an kill the value of your car.
    1968 firebird....in the works!! all matching numbers http://www.cardomain.com/memberpage/820973
    Nov 2004
    Forney, TX
    Default
    79, the links do not work, and I've looked all over that site for this car and can't seem to find it, where is it located?
    __________________________
    Boyd
    1972 P/T Style Chevy Short-bed - coming soon
    Specialty Auto Services
Posting Permissions
  • You may not post replies
  • You may not edit your posts
