    Page 1 of 42 1 2 3 4 5 6 11 ... LastLast
    Results 1 to 20 of 831
      Dec 2010
      Apex, NC
      Project TechnoStang 66 Mustang Coupe
      Well, this is what I have to start with. Named it project TechnoStang because I plan to incorporate a lot of technology into this buildcentered around an in dash touchscreen (automation control is my day job). This will be used purely as a street car and any ideas are welcome.
      Name:  Mustang Day 1 001.jpg
Size:  130.7 KBName:  Mustang Day 1 003.jpg
Size:  129.6 KBName:  Mustang Day 1 004.jpg
Size:  123.6 KBName:  Mustang Day 1 006.jpg
Size:  150.3 KBName:  Mustang Day 1 002.jpg
Size:  258.4 KBName:  Mustang Day 1 008.jpg
Size:  208.0 KBName:  Mustang Day 1 005.jpg
Size:  91.2 KBName:  Mustang Day 1 007.jpg
      Lawrenceville, Ga.
      I'll be watching .... your day job should lend to this build with some kewl upgrades.
      Ratt 46
      san diego
      nice project! good luck!
      Dec 2010
      Apex, NC
      Interior Stripped
      I guess this is progress :-). Neighbors stopped by so I put em to work! My oldest son , Jake, helped a lot. Front end and all exterior chrome, etc is next.
      Look forward to seeing where you decide to take it.
      Dec 2010
      Apex, NC
      Nothing earth shattering to show but the easy part is almost done.
      http://albums.phanfare.com/isolated/eMFTdKxz/1/4972696
      Dec 2010
      Apex, NC
      Car is stripped. Need someone that does bead blasting in NC. Any suggestions?
      DFW (Dallas TX)
      Cool project!
      Rick C.
      http://www.cardomain.com/ride/541371/4
      Used to be known as PonyCar'68
      Dec 2010
      Apex, NC
      Some updates today........I ran across a 2004 Aluminum block 4.6L and a set of 4V heads so looks like I will be going the modular route. I will need a rotating assembly for it and recommendations are welcome. I will most likely put a turbo on it. Also talked to a body shop so may get it in sooner than I thought.
      SF Bay Area
      Quote Originally Posted by Crestronwizard View Post
      So I take it you're planning on something big for the front end of this car? Tube frame?
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
      Jan 2010
      Calgary, Alberta, Canada
      Nice. I'm going the same route, 4.6L 4V. I've been wanting to add a turbo as well but have decided against it due to packaging. My car ('67) is significantly wider and I'm going with a tubular front end w/struts. I'll be interested to see what front end you go with and how you package the turbo.
      I am leaving my options open though. I'm planning for a ~400 HP NA motor at about 10:1 so I'm still open for some pressurizing. These motors run cool and have such good heads that you can easily throw 15 psi at them at 10:1 with out issue.
      I look forward to the build!
      Cheers,
      Wes
      Jan 2010
      Oh ya, rotating assembly: I went with used cobra stuff. The forged crank (96-98, 03-04) is supposed to be good to 900HP and 8500 rpm. The 03/04 cobra rods are Manley H beams good to similar power levels (96-98 cobra rods are junk). They can be had used for $200-300 each.
      Not sure what you know about mod motors but stay away from the B heads if you can, you cant find intakes very easily.
      Cheers,
      Wes
      Dec 2010
      Apex, NC
      Yes, exploring options now but regardless the shock towers are coming out :-). Thanks for the tips on the crank and rods and heads.
      Dec 2008
      Columbus, IN
      Nice project! I am also a fan of the 4V engine. They are very efficient at making power. Mine has dynoed over 500 hp NA. As Chunger illuded to, Its a wide engine due to the double overhead cam design. This will require you to remove the shock towers. There are several manufactures on this board that can help. I would start by looking here www.totalcostinvolved.com/mustangf&r_intro.cfm
      '66 Mustang
      '67 FireBird https://www.pro-touring.com/forum/sh...light=firebird
      '68 Barracuda
      '69 Mustang Mach 1
      '97 Mustang Cobra
      '04 Mustang Cobra
      Dec 2010
      Apex, NC
      Pressure Washed
      Put Jake to work and did some de-greasing. Car smells less musty now :-). Picking up the 32V 4.6 tomorrow. I really need some suggestions for the front and rear suspension. Been browsing posts and the TCI looks pretty good......
      Name:  Mustang Pressure Wash 002.jpg
Size:  192.3 KBName:  Mustang Pressure Wash 004.jpg
      Dec 2010
      Out in El Paso, TX
      nice project there man. Kinda strange that I'm selling my 3V 4.6 on the cheap too. Keep us posted on the build. I would go AirRide on that baby!
      low is all I know..
      Nov 2010
      sweet home alabama
      Quote Originally Posted by 2blownstangs View Post
      pm me with a price for the 4.6 and some more info on it
      Cartersville, GA
      Nice project! I have 3 customer Mustangs in the shop right now (a '66 gt coupe, a '67 "Gt500E" convertible, and a '65 fastback that is getting the R-model treatment). None are getting mod motors unfortuantely...I've been itching to do one.
      Joe Hinds
      Dec 2010
      Apex, NC
      I am looking at ridetech's system. Anyone done one on a Mustang? Pro's and Con's?
