Results 1 to 11 of 11
    Feb 2008
    Waco, TX
    Default LS1 vs. S10 Rear Disc on 2nd Gen Firebird
    I've read the various posts about converting to LS1 & S10/Blazer rear discs on a 2nd Gen F-Body. They both appear to be a great alternative to the factory '79-'81 WS6 Integral E-Brake set-up. My question is which set-up is easier, more readily available parts, cheaper, etc. I'm ready to begin accumulating parts, but I'm wondering which "package" is the better option.
    Ken
    Montgomery, IL
    Default
    Welcome. 1 post in two years????
    I've been doing the same research. In my climate, the Blazer stuff is all rusted junk by the time those trucks make it to the yards. TX would be completely different. The LS1 stuff seems to get picked over too fast and by the time I come across one, it is partially stripped down. I am thinking I will just go with new stuff as the part prices are not too tragic on GMpartsdirect. I am leaning LS1 at this time 'cause I don't like how deep the Blazer rotor is. I doubt I am ever going to be putting 15's back on my car so size of the LS1 set up is not really a problem for me. I am planning a 13" set up for the front so I would think a 12" rear would be a better balanced set up.
    71 Formula, 455 SD/KRE D-Ports, Crower solid cam, TKO 600, 3:73 Eaton posi. 17" ARE 200s, , 1LE brakes, Koni, Rancho adjustable bars, Hotchkis springs
    Jul 2009
    Manchester, Iowa
    Default
    I have also been wondering what the difference is. I can get either from a local yard but just don't know which is the better set up. I have been looking into doing this on my 71 chevelle 12 bolt. There is a spacer that needs to be added right?
    Loganville, GA
    Default
    The 2wd blazer rotor depth is the same as the LS1, the 4wd ones are too deep and won't work. Otherwise they are basically identical other that the diameter. I have done both the LS1 and S10 brakes btw.
    As for a spacer, you may need one, usually about the thickness of the drum backing plate. You can cut out the backing plate for a spacer or use washers, I think I used 1/8" washers, but I checked it first by assembling the setup and checking to see if the rotor was centered in the caliper bracket/abutment.
    2012 Camaro SS LS3 6-spd
    2003 Suburban 2500 8.1L
    1975 MGB Roadster
    2003 GSX750F Katana
    Montgomery, IL
    Default
    I didn't know they were the same depth. From the pics I have seen the Blazer looks deeper: http://www.nastyz28.com/forum/showthread.php?t=109454
    Seeing that you have done both, which do you prefer?
    Texas
    Default
    One difference is on the S-10 e-brake bracket is integral to the caliper bracket whereas the LS1 is a separate bracket that will probably require some fabbing to work on a different vehicle.
    -Bob (66 Nova)
    Loganville, GA
    Default
    Quote Originally Posted by Zee View Post
    That picture does make it look deeper, but they are very close. As for preference, they should both work equally well, rotor diameter being the main difference and that is only 1/2". The S10 setup does allow for 15" wheels while LS1 require 16"+ wheels.
    1975 MGB Roadster
    2003 GSX750F Katana
    Feb 2007
    Vancouver, WA
    Default
    If both will fit your wheels, I'd choose the LS1. Bigger dia and thicker rotors. As said, they do require you to fab an e-cable bracket, while the S10 has it built in.
    For the spacer, these will work if you very slightly enlarge the ID of the big hole. They are bearing retainers with the GM bolt pattern, and 3/16" thick. I got them from Dutchman, about $10/ea. Or you can make your own, like I did. (these are sitting on my shelf still)
    Feb 2008
    Waco, TX
    Default
    I have GM numbers for most of the parts required for the S10/Blazer conversion, but I'm still missing the Pass Caliper P/N. Does anybody have a GM Part Number for the S10 2WD Passenger Side caliper?
    -Ken
    Walton, NY
    Default
    I'm partial to the Blazer setup.
    Feb 2008
    Waco, TX
    Default
    Quote Originally Posted by woody80z28 View Post
    Because it clears 15" rims? Or another reason(s)?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
