    Page 1 of 5 1 2 3 4 5 LastLast
    Results 1 to 20 of 82
      Aug 2008
      70 nova project -I took the long route!
      Here is the nova when i first got it. I bought it out in concord, ca for $800 and one heck of a long day. The plan was to build a nice street car for around 3,500 and cut all the corners and get her done in 6 months LOL I know, I know!
      interior
      1970 chevy nova 350 motor, 350 trans
      Motor rebuilt and dressed up
      Installed
      so I built a cage for her ...
      add some interior Pick&pull + kragens auto+craigslist =)
      wheels & black primer & cowl hood
      Aug 2008
      I was pretty happy with the rebuild and was looking to get the car painted and was still with in the 3,500 dollars i wanted to spend. Then I made it out to my first goodguys event and said crap!!!!!!!!!!!!! LOL time to redo the nova all over again! I want to go the pro-touring route~! Budget who knows?
      Bodywork first
      Aug 2008
      I then pulled the rebuilt 350 & 700r4 trans, and went the lsx route. Added a 9inch rear with 410 gears, rebuilt 700r4 tranny. And add Bigger piston calipers and bigger rotors from a 2000 SS camaro.
      Nova motor almost done
      the sheild over the manifold has a hole but that will be replaced by long tubes soon
      front view minus the alternator
      nova update motor in:
      Some more nova work over the weekend
      The Motor is coming along, need to clean up my wiring and it just needs fuel
      9-inch diff 4.10 Gears
      Ls1 brakes Driver
      Passenger the shock broke, i hate pot holes
      Aug 2008
      Update mock up of nova seats
      1999 Acura rl power seats
      Found out i have a kid on the way my first kid and also my man child so the cage had to go and I mocked up my rear seats for the nova a little more
      Aug 2008
      Wheels are in and on 18/8 boss 338
      Car at the muffler shop going with the set-up i already had 2 chamber flowmaster mufflers with turn downs
      Shot from the rear of the car when it was on the lift
      Oil pan shot for the people asking truck pan cut and sealed
      I took the first drive in the nova this weekend and if i do say so myself very very worth every penny and long weekends i spent getting eveything installed the car is very powerful and smooth and starts on the first try
      Long Beach, Ca
      Good to see another Nova around!
      I want to go the LS route as well. Keep us posted on the engine install!
      Edit: D'oh! I guess the engine is in and running already! Nice work.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      yeah cool project!
      San Rafael
      Your Nova looks GREAT..... Keep up the good work
      Paul
      Aug 2008
      Thanks alot, really appricate the comments lots of more work to go
      Jan 2010
      South Carolina
      nice work. that makes me jealous
      wanna get mine in some sorta shape.
      what would it take to put stock LS1 camaro brakes on my 77 Nova?
      it has disc now, single piston
      Aug 2008
      THANKS
      will look into that info for the 1977 nova, I know they have a different set up in the front then we do.
      Need to figure out what to do regarding my coolant cross over pipe ones missing out the back of the head. And the front I have not ran to the radiator yet...
      Aug 2008
      The ride height before
      The nova Ride height test fitting with new springs
      Yes my caliper was on the ground, and no it was not hanging from the line it was disconnect just sitting under the car.
      A shot with the completed brakes and rims together
      Nov 2009
      Country Flag: Argentina
      That look great!
      I cannot wait to finish my 72 Nova, "Another member on the Boss 338 Team!"
      yeah very nice rims but ;) I'm also biased!
      Aug 2008
      Thanks a lot guys more updates...
      The Motor all complete minus the air cleaner Which i cant seem to find.
      Car sitting in the garage after last nights drive, that was the longest i've driven it so far. water on the ground was from filling up the radiator for the last time now that all the leaks in the system has been found
      Aug 2008
      My next plans are to remove the shackles in the rear. I hate the ride with them on the nova, as well as the car seems to sit higher on one side because of the leaf springs position on the shackle. Also i'm moving toward interior to get the power seats active and mounted. As well as getting new autometer speedo, tach and fuel gauge to replace the factory stuff.
      Jul 2008
      ohio
      Quote Originally Posted by 96t/acj View Post
      what break setup did you go with kind of looks to be stock off of a gm car. im looking at getting a setup off a stock 98-02 camaro or trans am or firebird
      have another question when you switch to a carburated LS does it change power or torque
      edit again woops another question for you not sure if you have anwsered this or not but what are the seats out of im really liking them alot
      Aug 2008
      Quote Originally Posted by craigs73 View Post
      These are the stock brakes off of a 2000 ss camaro, lots of people do not want to admit it but the dyno has proven to produce more power with a carb after it has been tuned . Seats are out of a 00 acura rl... I also have a pair of 01 brakes, Front & Rear left over if u want them. (LET ME KNOW)
      Jul 2008
      ohio
      sent you a PM have you checked out stevesnovasite. lots of great people over there with lots of knowledge to help you as well.
      Aug 2008
      PM replied, Yeah im on steves as well.....
      The front seats of my nova have been removed, Im thinking of going in a different direction with something that will sit a little lower and be manuel seats. the wiring for the heated seat, plus the air bag, plus the 24 way option was just a little to much for my liking. ....
      New two piece carpet with padding....
