    Results 1 to 11 of 11
      Oct 2009
      Southeastern Michigan
      SPC Tubular Lowers + SC&C Stage 2 Woes
      Need a sanity check, please.
      G-body SC&C Stage 2 tall ball joint falls, literally, out of SPC lower arm. All parts are brand spankin' new. The arms were shipped with ball joints. The local machine shop removed the other and pressed in the new tall ball joints. When I picked up the parts, the guy said they went in waaay to easy and expressed his concern about it being right.
      What could I be overlooking? Anybody else ever run in to this problem? The other ball joints were knerled at the mating surface but I don't think the tall ball joints are. Trouble is definitely afoot in tolerance town. grr.r.r.r.r.r.r.r.......
      May 2008
      SoCaL-Pico Rivera
      Have you called SPC? I am sure Marcus can and will help you out.
      Mountain Springs, Texas
      This has come up before. They need to be tack welded in. The holes are ovesize for replacement ball joints which are slightly larger. The tall balljoints are not, they are stock diameter.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Oct 2009
      Thanks. That's a good explanation.
      Should they be tacked on the bottom side in 12, 3, 6, and 9 o'clock positions?
      Quote Originally Posted by cornfed View Post
      Not sure but I was going to just put the tacks on the balljoints only to hold them in since the weight of the car holds them in normally. That way I don't have to weld on my control arms.
      Oct 2009
      Thanks for the info. I'll let this ride. Maybe a veteran will chime in and share their experience. If not I'll clean up, grab a barley pop, and exercise the search button. I was hoping to knock out the front suspension today so I could reattach my front clip.
      In the meantime, I've stripped the rear suspension from the car. After dinner I'll begin installing the new bits. Tomorrow's project is finish the rear suspension and then begin installing the rear disc system. I probably should start a project thread. . . .
      Oct 2009
      You are my favorite Pt.com member.
      west michigan
      my first thought was to check the taper but upon reading I realized you meant the other end.
      England
      Being as this issue has been going on for 2yrs what would it take to put a small note in the box advising the buyer to weld the ball joint in if loose instead of finding out after putting it in.As this job is a pain the back side to do.
      Oct 2009
      I'm certain Marcus told me this detail and I simply forgot it. Why this detail isn't in the instruction set- I don't know. Either way, the LBJ's are stitched and the front suspension is assembled except for swaybar, alignment, and shocks.
      Thanks again for the holiday weekend help. Front clip isn't on, but hopefully after this weekend it will be.
