    Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 61 to 80 of 138
    1. #61
      Apr 2010
      battery is in.... anyone know of any good battery tenders?
      I think I've found a way to get the NRG slim hub and the NRG slim quick release to work together. The tricky thing is getting the power to the horn switch. I think I'm going to use a spring to carry the power from the inner column to the switch. To make it work with the stock components, I'd have to cut the steering wheel shaft. After reading into the instructions, it states that the NRG slim hub is NOT designed to work with the NRG thin quick release. Lame and misleading . Oh, well. I plan on making it work without cutting the shaft.
    2. #62
      Sep 2007
      Southern California
      Looking real nice. A great idea on the horns. Given the distracted driving going on a serious wake up is sometimes needed and you don't want to have a horn that goes "excuse me" you want "Wake the **** up!" when the jerk is wandering into your lane.
      How do they compare to the factory horns is sound level?
      Jon U.
      1968 GTO - SC&C Suspension, Forgeline SO3 Wheels
      Build Thread
      1967 911 with a few mods
    3. #63
      Apr 2010
      I have them on my bugeye WRX. I'm not sure there's really a comparison that I can put into words. To put it in perspective, the factory horns sound like Tweetie Bird is politely requesting you to check your road behavior and the Hella Supertones sound like a hoard of demons escaping from the bowels of Hell.
      I highly recommend them
    4. #64
      Apr 2010
      A few more minor updates...
      Getting the horn to work with the tilt column and NRG slim quick release hubs / quick release adapter. This adapter isn't the same as the thicker ones. When you mate the steering wheel to the hub, you have to turn the quick release, not the steering wheel. I used a spring to carry the current from the positive to the horn. A preliminary continuity test yielded that it should work when everything is powered up.
      I had to widen that hole that the spring goes through, so the stock electrical connectors wouldn't work. After reading the instructions, they stated that the NRG quick release would not work with the NRG slim hub adapter. Well, they won't in stock form, but with a little cutting and utilizing the spring, they will work. I'm sure there's a better looking connection than using the spring (which I may explore later), but this will work for now.
      As you can see, it's a lot thinner than the non-slim mounting options.
      Also, I ordered some Lokar pedal covers, bud decided to go with the matching Momo Nero covers to match the steering wheel:
    5. #65
      Apr 2010
      Now for the A/C...this little thing works like a champ! I got it from e-tools direct on ebay. I think it cost around $150. Worth every penny.
      Some random pics throughout the installation...
      I hope everyone has a Merry Christmas!
    6. #66
      Houston, TX
      Quote Originally Posted by ModernMuseum View Post
      Now for the A/C...this little thing works like a champ! I got it from e-tools direct on ebay. I think it cost around $150. Worth every penny...!
      Do you have the ebay link to that tool? I'm interested in buying one of those, since I'm about to do my VA installation.
      Thanks.
      Tu Ho
      Firebird V2-LS swap
    7. #67
      Apr 2010
      The tool was this one: Mastercool 71550 A/C Hose Crimper Tool Kit
      Here's an Amazon link:
      http://www.amazon.com/Mastercool-715.../dp/B000WBQ4U2
      Also, you may want to fix the link in your signature
    8. #68
      Houston, TX
      Fixed the project link, and thanks for the link to the tool.
      Tu Ho
      Firebird V2-LS swap
    9. #69
      Apr 2010
      Still waiting on Prodigy Customs for a lot of parts... :\
      Anyway, the Death Machine is starting to look like a drive-able vehicle:
    10. #70
      Apr 2010
      Getting closer....
    11. #71
      Apr 2010
      Sunny Flordida
      Lookin freakin great!!!
      [/URL]
    12. #72
      Jun 2011
      San Diego
      Looking good.....
    13. #73
      Apr 2010
      Thanks gents. I hope to have it wired up and ready to go in another month or two. The sauna outside really slows me down.
    14. #74
      Sydney, Australia
      Country Flag: Australia
      Wow, car looks awesome!
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
    15. #75
      Apr 2010
      Thanks - hopefully the front end will settle a bit more. It has 2" dropped Hotchkis springs in it, but the lighter LS motor isn't allowing it to drop much at this point. I guess I'll try and do a rough alignment, drive it around some, and then take it in to get the official alignment done. I'd like the top of the tire to be even or slightly inside the top of the fender....not sure if that's going to happen with the current suspension though....
    16. #76
      Houston, TX
      Car looks great. Do you still reside in Houston? I'll be moving to Houston in a few months, and it would be great to come by and check out your car.
      Tu
      Tu Ho
      Firebird V2-LS swap
    17. #77
      Apr 2010
      Yes, sir. I'll be in Houston for a good while. Drop me a line whenever you come in and make sure and bring the firebird.
    18. #78
      Feb 2010
      Central NJ
      Looks Sick! Nice work!
      Do you have any shots of the wheels? its hard to make out the design...either way, the car looks bad ass!
      -Sean
    19. #79
      Apr 2010
      I believe they're Forgeline DE3P's. 18's all around - satin hoop with a glossy rim. Check out my flickr. There's a folder called "Death Machine."
      www.flickr.com/photos/modernmuseum
    20. #80
      Apr 2004
      Cedar Rapids, IA
      what did the rear view mirror come from?
