Results 781 to 800 of 877
03-23-2012 #781
03-23-2012 #782Thanks Bryce.
I work in the oil and gas industry and had spent some time early in my career comparing applied torque vs clamping force. What I learned from this is that these 2 things can be very different based on the thread lubricant used, easily on the order of 2 or even 3:1 kind of range. Also, I leaned that the best way to keep fasteners from coming loose is to lubricate them. I know this is counter intuitive but look at it this way. The more clamping force that you put into the bolt at a given makeup torque, the more the bolt stretches. Assuming you keep it below yield, it will maintain a load and therefore stay tight over a larger range of movement, especially thermal.
Anyway, enough blathering, I was trying to get to the question of what do you use for thread lube?
Wes
03-27-2012 #783
