Page 29 of 44 FirstFirst ... 19 24 25 26 27 28 29 30 31 32 33 34 39 ... LastLast
Results 561 to 580 of 876
  1. #561
    Jun 2009
    Phoenix, Arizona
    Default
    Quote Originally Posted by Wesley J View Post
    Does anyone know of a good wiper controller? I was driven nuts on Power Tour last year when I needed intermitant wipers.... I'm looking for something I can mount on the bottom of my dash and kinda hide. A stealth knob is kinda what I'm thinking.
    Cheers,
    Wes
    Wes,
    Scott Drake makes one that I have heard good things about. Check out the following link:
    http://www.drakeautomotivegroup.com/...2.aspx?wid=141
    Also Mustang Monthly did an article about the installation for a 1969 model. See the following:
    http://www.mustangmonthly.com/techar...all/index.html
    Great progress on the build, especially now that you have the engine!
    Cheers!
    68 Mustang Convertible
    408 Stroker
    5 Speed
    Coil Over Suspension
  2. #562
    Feb 2009
    Default
    I think what is most important is the drive line angle mesured from the tailshaft of the trans you want it between 0% and 3% down.
  3. #563
    Jan 2010
    Calgary, Alberta, Canada
    Default
    Quote Originally Posted by Cobraclone View Post
    Wes,
    Exactly what I'm looking for, thanks. Too bad I didnt find it before my Mustangs Unlimited order came in....
    Quote Originally Posted by 482supersnake View Post
    Thanks, it looks as though I'm pretty much right in the middle.
    Wes
  4. #564
    Jan 2010
    Default
    Motor mounts are done. I had the material laying around so I made them from Aluminum. One of the frame side mounts is done, I'll get the other done tonight and installed.
    Wes
  5. #565
    SF Bay Area
    Default
    Hey Wes, chiming in kinda late on this, but - there's a low buck approach here too. Late 70's F series pickups & vans had intermittent wipers as an option. It uses the standard ford in the dash mounting (not the stock 67/68 Mustang mount in the instrument cluster, tho. It's literally a plug and play solution to delay wipers.
    Hands down, THE best $10 junkyard upgrade I ever did to my Ranchero!
    chunger
    '68 Ranchero 500
    '70 Cougar XR-7 Convertible
    '98 Mustang GT Convertible
  6. #566
    Mar 2011
    netherlands
    Country Flag: Netherlands
    Default
    i have done the same thing with my 2 speed wiper. i replace it for a late 70's F series pickups & vans that had intermittent wipers. you need the wiper motor, switch and module.
    Greets Paul.
    '71 ford capri mk1 427 v8.
    '65 ford mustang 5.0 efi aod, running on LPG. Sold now.
  7. #567
    Jan 2010
    Default
    Motor is hanging from the mounts. Tranny mount this weekend as well as firewall contruction.
  8. #568
    Jan 2010
    Default
    Well, Shawn for Mascoll Designs (www.mascolldesigns.com) sent me my rendering late last night! I'm assuming that since the rendering is done that when I get home tonight the car will be too..... Wishfull thinking....
    For some reason the forum resizes (and poorly...) so here's a link to a slightly bigger/less manhandled version: http://mustang.weshill.com/?p=938
    Items to note:
    - Grill opening below the front bumper - morrors the shape of the upper grill
    - Soft black paint on the hood/trunk
    - Hood scoops a la GT-40
    - Satin chrome
    - Door locks removed
    I dont even want to think about how much money in ink this is costing on the plotter at work at 4' x 6'......
    Cheers,
    Wes
  9. #569
    Texan Back in Texas!
    Default
    Awesome
    1965 Falcon Hardtop
    Build Thread: http://www.pro-touring.com/showthrea...847#post798847
  10. #570
    Jan 2009
    Chattanooga, TN
    Default
    That rendering looks great wes! It looks like youre going to shorten the hood a bit? And some nice side vent work as well. Are you going to make those functional?
    Stephen S.
    1967 Ford Mustang 4.7L, T5
  11. #571
    Jan 2010
    Default
    Quote Originally Posted by MSTSFabbed View Post
    To be honest, neither, thats just how the rendering came out. I am going to make the hood vents functional though.
    I'm planning to take 6 days off here starting this weekend with my time split between family and the car. I'll try my damndest to stay off of my motorcycles and actually get some work done! Tranny crossmember is done and turned out great.
    Wes
  12. #572
    Roanoke (FortWorth) Texas
    Default
    Wes
    Mind posting a pic of that. Im about to start making one myself and could use some ideas.
    Chris
    Total Cost Involved - Ridetech - Fatman - Total Control Products - Gateway Performance - MaverickMan Carbon
  13. #573
    Jan 2010
    Default
    Quote Originally Posted by GrabberGT View Post
    Will do. Keep in mind that I effectively have a full frame and have chopped out large sections of my floor.
  14. #574
    Jan 2010
    Default
    Quote Originally Posted by LowFast View Post
    Great progress, what is your inside of frame to inside of frame measurement? Curious as to how wide the thing is at the header. How much larger would you say it is compared to the 4.6 DOHC, I had read that it was supposed to be smaller but that appears to not be the case.
    The 4.6 4V I have measures 27" and a bit at the widest point. The 5.0 4V is a hair over 29" at the widest point. Wow. Considering that this thing weighed 473 pounds with the crate, wiring harness, computer, fuel pump/reg etc shows that this thing really does acutally weigh 420 ish lbs.
  15. #575
    Jan 2010
    Default
    Here she is. 1.5" DOM tubing with sleeves at the bushings. The exhaust cut outs are from 3 1/2" 3/8" thick steel. I stood on the tranny and it doesnt deflect at all.
    Motor mounts, not quite finished yet. I obviously need to finish welding on the frame side but I'm also going to add additional bracing to the aluminum motor mounts.
    I start 6 days off tomorrow and I'm going to go hard on the firewall.
    Wesley J
  16. #576
    Oct 2005
    Default
    Wesley,
    Looks really good! I like how you made the tranny x member! It's nice to see the new coyote in a project like mine before me.. gives me lots of things to take notes off of. My roadster shop front clip is almost done and I have pre-ordered my Roushcharged coyote motor! I'm pretty excited!
    Cheers
    Tom
    PS I just got transferred to Calgary for work and am supposed to be out there on Monday - it would be cool to check our your project sometime..
  17. #577
    Jan 2010
    Default
    Quote Originally Posted by 67greengt View Post
    Wesley,
    Cheers
    Tom
    Thanks. Drop me a PM when you get here and we can plan a time to drink some beer in my shop and compare notes. Good timing, you get here right before stampede!
    Wes
  18. #578
    Default
    Thanks. Looks beefy. That exactly what I need for mine but with the cutouts opening up towards the floor rather than down. I need more clearance for my exhaust to run as tight to the floor as possible. My plan is very similar to yours. My main obstacle is coming up with how to attach it to the stock thin frame rails. My welding experience is minimal and Im afraid thru-bolts would tear the frame rails.
    Chris
  19. #579
    Oct 2005
    Default
    Thanks Wes! Sounds good
  20. #580
    Aug 2008
    Default
    i just went through this entire thread, love the project.
    i have a fox, plan on a forged coyote swap this winter.... i am also running the SN95 spindles with 13" rotors... i picked up a set of 4 piston wilwoods, but the rotor "hat" offset is so shallow, that they will not clear the "spokes" my cobra wheels. im just curious if you have checked this with your factory style wheels.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
