    Page 17 of 30 FirstFirst ... 7 12 13 14 15 16 17 18 19 20 21 22 27 ... LastLast
    Results 321 to 340 of 586
    1. #321
      Indiana
      Rod, it looks like you're kicking butt and having an awesome time in the process! Nice job and the Camaro is looking great!
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
    2. #322
      Lawrenceburg, TN
      Quote Originally Posted by Roberts68 View Post
      What is the backspace you are running Rod? Is it the exact same wheel/tire combo as the rear?
      That looks great!
      yes same front and rear now
      Wheel Diameter: 17 in.
      Wheel Width (in): 9.500 in.
      Backspacing (in): 5.500 in.
      Offset: +6.00mm
    3. #323
      Lawrenceburg, TN
      Quote Originally Posted by Yelcamino View Post
      Thanks Herb, I'm sure you will see my name cross you're desk (again soon) as I hope to get some new TQ's built to go with the new arms that Crosby has been working on, the single adjust ridetech Shocks I have are awesome, its hard to explain to many how smooth they are and the recovery time between problems is incredible
    4. #324
      Grain Valley, MO
      Hi Rod, I've really enjoyed reading each page of this build and am glad it has worked out so well for you! I am 1 month from starting on my 68 and was hoping you could verify the following part#s you used for mounts and headers. Did you have any issues with clearance using the Dynatech headers? If you have a pic of the driver's side that would be great. Thanks.
      Trans Dapt 4592
      Dynatech 715-11410
    5. #325
      Lawrenceburg, TN
      Quote Originally Posted by Mizzouri View Post
      Trans Dapt 4592
      Dynatech 715-11410
      do you have an automatic or manual transmission, the dynatechs fit very well but then I decided to stay with the old T-10 and the manual clutch linkage and the dynatechs did not match so I went to the short sandersons
    6. #326
      Grain Valley, MO
      The plan is to run a T56.
    7. #327
      Dec 2012
      Las Vegas, Nevada
      what were you running for your rear suspension before the upgrade? do you like running same size tires on front and rear alot better than a staggered setup? im currently building a 68 camaro to do some autocrossing and hopefully earn an invite to the optima challenge like you did. I noticed there are 4 classes on the board where would i find info to see what mods are allowed for each class? hope to meet you, see your 68 and maybe get a ride around the cones real soon at an event in the next month or two! Congrats on your event win btw !
    8. #328
      Lawrenceburg, TN
      Quote Originally Posted by RBEAST View Post
      The car has always been leaf spring, I upgraded the shocks to ridetech from QA1s, the Ridetechs are smoother and recover from obstacles (bumps,curves) faster
    9. #329
      Lawrenceburg, TN
      Another Great weekend! and a smooth start to the new Goodguys race season
      Like I said another Great weekend! and a smooth start to the new Goodguys race season, I had a few updates to the car for the new season, the biggest change is the front wheels width, I stepped up to a 9.5" wheel and a 275-40-17 tire, I rolled the fender wells a little. During the first run the turn-in was almost to great, the car was turning so quick it made the rear end a little loose, so I added a little toe in and that smoothed it out some, with the wider front tires the steering input from me had to be smoother so the car was less jerky....after my shake down run the adjustments worked and I ran faster,
      It was a weekend battle with a freind of mine from Southern California Brett Cambell from the Fab53.com shop it wa a good day saturday and and afterwards we went to Rob MacGregor's motor home for a corn toss game and some beers
      Brett was also going faster all weekend and his final run sealed it I couldnt get Jane to get there without one more run, I ran only 5 runs all weekend, 1 less than everyone else because they moved me inside the show grounds next to the Pros and they said because I was moved I lost that turn in the line-up
      heres a pic of Brett on his winning run
      I gave it one last run and the timing was over at 12:00 sunday and I finished in second
      Time to pack it up and head to Del Mar Goodguys
    10. #330
      Roanoke (FortWorth) Texas
      Great story and congrats on the 2nd place finish in such a stacked field. But the the part of the story that really got my attention was the corn toss game. Having made my own game for the back yard, I cant help but notice the quality in Robs build here. Hell, even his corn toss game has speed holes. LOL... and that V8 logo rocks.
      Chris
    11. #331
      Lawrenceburg, TN
      Practice makes perfect!
      Practice makes perfect! so I have been told and since the Del Mar Goodguys event is this weekend I needed a little more time with the suspension changes done to Jane, so I headed to Adams Motorsports Park on Tuesday to tune and shake off the cob webs, and on the way there I stopped and a 7-11 for water and ice and a new issue of Camaro Performers, and I find an article written by a friend of mine David Pozzi, about camber, so I took a picture of myself using his story at the track to adjust my camber
    12. #332
      Lawrenceburg, TN
      I found this from Jay Lenos Garage on his newest project and thought, when did Jay Leno see my car and decided to copy it?? cool!
      heres Jays Render
      and my car
    13. #333
      Lawrenceburg, TN
      Turn, Turn, Turn
      so one of the things I always work on, is the turning ability of my car "Plain Jane" and some of the weapons out there are Ridetechs Tru-Turn and CPP's C-5 spindle for 1st gen camaros,I have had the c-5 around for awhile and now the tru-turn and here's a few pictures of the parts and measurements for everyone to look over and I will show some test and setups over the next few weeks on these
      ridetech VS stock
      CPP VS stock
      ridetech VS CPP
      CPP
      Ridetech
      stock
    14. #334
      Lawrenceburg, TN
      Thanks to Johnny Hunkins for the great pictures from Goodguys Delmar
      and I have a few projects on the way!!!! I very excited! to show everyone
    15. #335
      Lawrenceburg, TN
      more cool stuff showed up! I cant wait!
      heres a peek inside one of the boxes, even more adjustment now!!!!
      upper ridetech/Fox shock adjuster
      Hyperco springs! these things are sweeeeettttt!!
      remote canister adjuster
      stay tuned!!!!
    16. #336
      Lawrenceburg, TN
      More Ridetech with the new Tru Turn kit and NEW control arms
      new Tru Turn Kit from ride tech looks awesome cant wait to get it on the car!
      and I will unbox a few more parts to night!
    17. #337
      Jul 2010
      Monticello, MN
      Awesome Rod, it will be interesting to see how it effects your results.
    18. #338
      Wow it's Christmas! I'm sure you'll make good use of those new parts!
      GeoffP
      68 Camaro - LS1/T-56
    19. #339
      Lawrenceburg, TN
      I know HUH! its kinda scary, I hope combining Ridetechs awesome parts with my Hotchkis parts is the winning ticket
      Quote Originally Posted by GeoffP View Post
      ooohh yea! its going to be FUN!
    20. #340
      Lawrenceburg, TN
      Ridetechs new upper arms!
      I hope im not giving out any ridetech secret sauce, but here are the Brand new ridetech Upper arms, I snapped a few pics before it got dark outside
      just as I pulled them out of the box!
      upper shaft close up
      upper shaft with caster slugs in place
      I will get pictures up of the lowers tomorrow!
