    Oct 2008
    Durham,NC
    Default Wheel fitment ? on C10
    Can anyone if I might ask tell me will a 5 inch back spacing work on a 1967 c10 with drum brakes? Rally wheels came of a 98 1500 truck. Thank you in advance, Brandon
    Oct 2005
    New Washington, IN
    Default
    Front it will be a tad to much. Rear will be close, may fit but will probably need a bit of a spacer. the 71-72 trucks had a wider rear hat 5" would be perfect for
    Look at 67-72chevytrucks. com for more info
    1971 Camaro 427 in waiting
    1988 C1500 Daily Driver
    Oct 2006
    Corona, CA
    Default
    Those C10's basically take a 0 offset wheel (backspace right down the center) so we normally do 8's with a 4.5" and 10s on the back with a 5.5". Just to give you an idea. Stance does make a difference, is the truck lowered, stock, raised, etc....
    Dec 2009
    Default
    Quote Originally Posted by DriverzInc View Post
    I second that!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
