Results 381 to 400 of 443
12-10-2017 #381
In this video I install the new external fuel pump for the Corvette.
I needed another fuel pump to provided the additional fuel requirement that the Corvette will need when running E85.
Tools/Parts Used:
Rivet Gun Rivnut Installer: http://amzn.to/2i3Bcqx
Step Bit: http://amzn.to/2i2Q5t0
Push Pin Pliers: http://amzn.to/2jwHcIj
Trim Removal Tool: http://amzn.to/2k9jAhc
Center Punch: http://amzn.to/2zPfq58
Air Drill: http://amzn.to/2i1mVdE
AN Wrench: http://amzn.to/2jv17ri
Thanks everyone for all of your support!
Follow me on Instagram: https://www.instagram.com/bonecrrusherss
Follow me on Twitter: https://twitter.com/bonecrrusherss
Like me on Facebook: https://www.facebook.com/bonecrrusherss2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://www.pro-touring.com/showthread.php?64496
2014 Chevy SS LS3 / 4 Door
12-10-2017 #382
I installed a smaller supercharger pulley and a larger idler pulley on the C6 - in this I go over how to install both.
Parts/Tools used:
Edelbrock Upgraded Tensioner: http://amzn.to/2jm02CM
Edelbrock 3" Pulley: http://amzn.to/2kqNe1v
102.5" Belt: http://amzn.to/2krdtoo
01-21-2018 #383
Hello everyone!
I took advantage of the warm weather and took care of some maintenance items on the truck - and go over my latest updates.
If you are interested in the video - please watch it below.
Thanks!
01-21-2018 #384
In this video I go over cutting/creating the new fuel lines for the build.
I used -8 PTFE Hose for the fuel system - while this hose is a bit harder to setup - I won't have the gas vapor smell that happens with traditional stainless braided rubber hose - plus E85 won't break down this hose type.
Parts/Tools Used:
Fuel Line Quick Disconnect Tool: http://amzn.to/2z8gOxy
Evil Energy AN Wrench: http://amzn.to/2z84Eog
Air Powered Drill: http://amzn.to/2z8wgtP
Chisel Set: http://amzn.to/2C1bJFS
Pipe Cutter: http://amzn.to/2ASnGyg
NPT Tap: http://amzn.to/2z8u71e
Step Drill Bit: http://amzn.to/2C0cHSJ
PTFE Hose: http://amzn.to/2ASHNws
AN Adapter Fitting: http://amzn.to/2AD1XNS
45* AN Fitting: http://amzn.to/2ymutxk
90* AN Fitting: http://amzn.to/2ASHrWq
180* AN Fitting: http://amzn.to/2ym2yhg
90* AN Fitting to 3/8 NPT: http://amzn.to/2ASmNFV
Russell Fuel Filter: http://amzn.to/2Cc2rb2
01-22-2018 #385
I went to Corvettes at Carlisle this year looking for one part.
The part that I was looking for was a ZR1 hood.
A buddy of mine bought one of those hoods and put it on his Vette - and I thought it looked awesome.
So to help with aero and ventillation - I picked up a ZR1 hood and an ACS vented hood insert.
Also the ZR1 hood is made out of Carbon Fiber and is 1/3 the weight of the factory hood - so dropping some weight up front can't hurt either.
01-23-2018 #386Its dyno time! How much Horsepower did the Corvette end up making?
Find out in the video!
Car was tuned at PCM of NC - http://www.pcmofnc.com/
01-25-2018 #387I installed a Roto-Fab Radiator Cover for my Chevy SS.
If I had a stock SS - this would bolt on with no issue - but since I have an LSA supercharger, and a custom intake - the stock Roto-Fab radiator cover will not fit.
I ordered the bare cover - and notched it for my oil catch can.
I then primed and painted and installed the Roto-Fab Radiator Cover.
Tools/Parts Used:
VHT Engine Primer: http://amzn.to/2D1jmAe
SEM Trim Black: http://amzn.to/2mfZD5v
01-25-2018 #388In this video I update the custom intake for my LSA swapped Chevy SS.
I wanted to get rid of the polished intake pipes - so I started sanding them with 320 grit.
I then primed and painted and installed the painted intake pieces.
Tools/Parts Used:
SEM Paint: http://amzn.to/2mGY2pt
VCM Fender Fill Plate http://amzn.to/2gnfVdM
Cowels Trim http://amzn.to/2iH7c6C
01-25-2018 #389In this video - I continue the build by picking up a new Diff for the Corvette.
01-31-2018 #390In this video I tear down the Z06 rear differential - and start repairs on it by replacing the broken housing cover/mount.
Tools/Parts Used:
Harbor Freight Press: https://www.youtube.com/watch?v=athkd...
Kent Moore Bearing Tool J42194
Diff Seal - http://amzn.to/2E7jM6u
Diff Passenger Side Cover: 19132920
01-31-2018 #391In this video - I assemble and review the Harbor Freight 20 Ton Hydraulic Press.
Overall the install went pretty smoothly - I had to flip around the press I beam - and change the bolts on the bottom of the press since I put them in the wrong spot.
Hopefully these notes will help save you some time when you assemble your press.
Tools Used:
Harbor Freight #32879 20 Ton Press
02-08-2018 #392Hello everyone!
Here is the latest upload in my build series.
Check out the video below to find out what's next for the Vette.
02-10-2018 #393Registered User- Join Date
- Jun 2014
- 160
